@Storm905: I did some tests with audio where I reduced the highs on the input (Bojcha described this yesterday), and indeed they aren't restored anywhere near as much as I had expected or hoped. So there's definitely more to be done here. In extreme cases the old compressor seems to do this slightly better even, although when testing with music without such extremes the new one seems better.
it seems to have a wandering/phasy type stereo sound field, and subdues the vocals.
This stereo could be the stereo enhancer (Stereo Boost) that is normally combined with the old multiband compressor, it might be better to test with that turned off. Will check the voices - in the cases I tested so far I didn't notice much loss in them, and remember that the old compressor has a voice protection built in. The new one has nothing like that yet.
Also the new compressor seems to noticeably breathe (i.e. you can hear it 'working') compared to the old compressor, perhaps more evident on some other tracks than others.
True. The old one sounds 'flatter' - could be because it has more bands, could also be because it behaves differently. I've used the gates in the preset to reduce this effect but I definitely hear something there that I don't like, which I also hear on some FM stations - but I never heard it in Stereo Tool.
It might also be caused by the "RMS" detection mode, will have to test if Smart Peak works better (it probably does; PhantomFM actually already confirmed that last night. But I wanted to do another test with RMS based, because that *should* actually sound more natural).
Playing with the steepness control,while having a big effect, it still does not seem to produce the 'tonal correction' range as BBP. For example playing a 'thin' track (with little bottom end) and then a dull track, the BBP compressor seems able to produce a more consistent tonal output between those two tracks than ST does.
I'm using feedback compression, which means - among others - that differences are not corrected very strongly. Will have to play with it to see if it can be improved. Having said this, it DOES seem to outperform the old compressor in this regard (to my ears anyway).
EDIT: Band 2 freq in that preset loads at 500 Hz, same as Band 3. Assume that's meant to be ~150 Hz?
Yes!
