Beta 072 vst2x64 OBS 28.0.3
Saving presets seems to be broken and I don't know if it's Host related. It saved a 9kb file with no active settings even though I had imported a fleshed-out preset and re-saved it. Then upon closing the interface and toggling the "open interface when active" box, it reloads the settings the VST was initially loaded with. Very odd. 066 did not behave this way.
Going to try Reaper and report back.
edit: Okay yes it doesn't want to save a preset properly from Reaper either.
What are you doing exactly? I just tried it in Reaper (on Windows, I assume you're using Windows?) and I see no issues. I've tested the 64 bit VST2, with old and new GUI, and even 32 bit bridged. They all seem to work fine. This was with version 075 (which I'll upload in a moment), but nothing has changed in the last few beta's.
My steps, in Reaper:
- Load VST plugin (first time, so there are no earlier settings)
- Select a preset
- Save that preset with the "+" button in Reaper
- Reset all settings in Stereo Tool to factory defaults
- Select the preset that I just saved in Reaper
This loads everything again.
- Unload VST
- Restart Reaper
- Select VST again
- Select the earlier saved preset again
This also loads everything again.
Just to make sure, I saved to a Stereo Tool .sts file as well - that worked fine.
Edit: I also just looked through the code changes, and the only thing that changed in the VST2 code since BETA066 is the handing of the window size. This is weird...
