Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 131 32 33 34 3576 Next
PostPosted: Tue Mar 13, 2018 9:58 am
THIS BUILD IS BROKEN ON MACHINES OLDER THAN AN i7-4000 SERIES!
Stereo Tool 8.55 BETA040
Windows stand alone: http://www.stereotool.com/download/ster ... 55-040.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-040.exe
VST: http://www.stereotool.com/download/vst_ ... 55-040.dll
OLDER CHANGES:
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- near05 VST crash
- New skin
- Check Auto EQ behavior on sudden level changes, and initial Auto EQ behavior after startup
- Test NanoPi
- Classical preset
- Is pre AGC affecting audio levels? (With BS412) -> Not specifically for BS412, but it slightly reduces the level even if set a lot higher. Probably needs some offset.
- Aanvraag uren
- Add AM presets
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
Important: The CPU load is really high right now. I will optimize it later.
Also important: You can't just enable this new mode and expect everything to be fine without changing the settings. For small level differences there won't be a difference, but there will be for big differences. You'll definitely notice the slower attack on big level jumps.
PostPosted: Tue Mar 13, 2018 10:28 am
Hello Hans,
When I launch the application displays this error message
PostPosted: Tue Mar 13, 2018 10:52 am
Hello Hans,
THE PREVIOUS BUILD IS BROKEN ON MACHINES OLDER THAN AN i7-4000 SERIES!
PostPosted: Tue Mar 13, 2018 11:08 am
Hans,
It's a test on a more powerful processor, so reassure me, it's not a prerequisite?
PostPosted: Tue Mar 13, 2018 11:57 am
I get this error as soon as sound is sent into the VST:
Stereo Tool however stays running and appears to continue processing sound, except some of the scopes stop working and other quirkiness like that.
I'm guessing that's expected behavior for my CPU in Beta 40?
This is going to be fixed, right? :shock:
PostPosted: Tue Mar 13, 2018 12:43 pm
Hans,
No it's broken. I already fixed it, next build should run again.
PostPosted: Tue Mar 13, 2018 4:10 pm
:twisted: :mrgreen:
PostPosted: Thu Mar 15, 2018 12:37 pm
Stereo Tool 8.55 BETA042
Windows stand alone: http://www.stereotool.com/download/ster ... 55-042.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-042.exe
VST: http://www.stereotool.com/download/vst_ ... 55-042.dll
OLDER CHANGES:
- RDS: Add PTYN
- VST version no 4K
- Self test crashes
- New skin
- near05 VST crash
- Classical preset
- Aanvraag uren
- Add AM presets
- Test NanoPi
- Check out Butt
- WatchCat website
- Triple stuff
- One bass page
- Talk to chip
- 2 jaar
- Fardau
NOTE: Bass EQ
PostPosted: Thu Mar 15, 2018 1:00 pm
Hi Hans
Windows 10 64 Bit - PS Build 16299.309
[attachment=0]NAN-GUI.JPG[/attachment]
Error window will not go away after clicking close (it just reopens) for 4-5 times then the application becomes non responsive.
Regards
Rossco
PostPosted: Thu Mar 15, 2018 3:15 pm
Hi Hans
Regards
Rossco
