Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 130 31 32 33 3459 Next
PostPosted: Mon Apr 04, 2016 10:47 am
Ok,
I ll use the second mpx output ( low latecy probably output which is more accurate )
Latest beta of Stereotool with my latest changes on preset.
Enabled ..everything ( natural dynamics, declipper, .... )
check it
http://stream.cretanservers.gr/fmbroadcast
PostPosted: Mon Apr 04, 2016 10:58 am
so, 900 euro for a huge compression ?
I can do it for 0 euro - everyone can do a hyper compression .
The thing is that NOT everyone can do a very balanced, nonHUGE compression sound , that is not fu*k your ears !
And for a web player, you must put the processed non pre-emphasis output. not a sound that must be inserted into the transmitter...
Web browser don`t have build in transmitter .
Bojcha said , that he wants the output from the receiver (the FM receiver)...
PostPosted: Mon Apr 04, 2016 11:58 am
Well - me and DJ Doggy have slightly different opinions on things most of the time - but I can't disagree with this one :D Especially the first part, regarding 900 Eur for the squeezed audio :D
Also - wanna prove the point - insert RAW MPX sample recorded off air.
PostPosted: Mon Apr 04, 2016 12:56 pm
Slawomir, we don`t have different opinions, just different views of the things :)
But as you already agree with me , that was very nasty one , a ?
PostPosted: Mon Apr 04, 2016 12:58 pm
7.85 BETA053
Windows stand alone: http://www.stereotool.com/download/ster ... 85-053.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-053.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-053.dll
CHANGED:
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Delossifier: Lay Down breaks Delossifier, sounds really bad! (And it's not MP3). Detection and reconstruction both fail!
7.85 but after NAB:
- Absolute Highs: Optimize performance: Check log()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly?
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem?
LATER:
- O skin
PostPosted: Mon Apr 04, 2016 2:31 pm
worst ever!
PostPosted: Mon Apr 04, 2016 4:41 pm
Here is something, absolutely not very special. Just ACG and MB1(digital)
Direct record from the FM receiver! Level of the record is at -6db.
Slawomir, can you tell me - did you feel that compression ? :). Yes - it have compression, but did you feel it like that stream (if you remember what it was).
The little noise floor is for prove it`s from receiver.
http://www111.zippyshare.com/v/HsgmxSUt/file.html
For real sound , you must download the file - listening from web is with low quality.
PostPosted: Mon Apr 04, 2016 8:57 pm
Let's talk about the latest beta of stereotool,
( by the way , i ve changed multiband compression a lot right now ) check it for youself and please give me feedback on the specific topic ( v2 )
Indeed , stereotool restarted while changing settings on " absolute highs " .
With latest beta it doesn't restart ( crash )
With my extreme settings it just rocks :) ( for my taste and some other radiostations )
( I ll try to give you my REAL MPX RECORDING 192 khz with Top40 songs soon :)
Dooooooooont shooooooooot me !!
PostPosted: Tue Apr 05, 2016 12:00 am
Camclone, kanonise na sou steilo tous filous mou apo to hrakleio ekei na sou paroun to preset :P :)
ps.
sorry for the Greeklish !
Bojan, where on earth r you..!
PostPosted: Tue Apr 05, 2016 7:45 am
Heheheh!
Let's sqeeze all settings at max efficiency .. ( or at max distortion ) :D :D :D
Let's make some more presets guys! , stereotool NEEDS FM BROADCAST PRESETS .
fm broadcast presets means = LOUDNESSSSSS WARRRRRRRRRR !
sound record companies will scare with it and will stop clipping their CDs mp3s :) :mrgreen: :mrgreen:
