Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 130 31 32 33 34 35 Next
PostPosted: Thu Aug 06, 2015 3:33 am
Stereo Tool 7.71 BETA025
Windows stand alone: http://www.stereotool.com/download/ster ... 71-025.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-025.exe
Windows 32 bit VST: http://www.stereotool.com/download/vst_ ... 71-025.dll
Linux 32 bit:
http://www.stereotool.com/download/ster ... ETA771-025
Linux 64 bit:
- Fix Linux version (someone mentioned that it crashes after a few minutes, on Ubuntu 14.04 - re-check with Valgrind) -> Done, found a few issues, Valgrind shows 0 errors now both for command line and GUI versions.
- Reduce memory usage further (check all MAX_SAMPLES_44K arrays including SS and multi_samples) - Effect is small (about 0.5 MB) - not worth the effort.
- Check all #pragma messages.
- Fix >48 kHz Normal Output issue in stand alone version.
- Fix reported glitches/hiccups?
- Optimized Stokkemask exciter code
- Optimized output to lower sample rate sound cards (includes plugin hosts). Overhead (CPU load even when all processing is disabled) is greatly reduced.
Risky change.
- Tested a large number of other small things (there were a bunch of remarks that I placed throughout the code, and most of them are removed now).
- Fixed FM tilt correction GUI issue.
- Exception reported by DJ_DOGGY fixed.
- Make OldSamples buffers (and potentially others) dynamic to save memory - Currently allocating 85 MB just to display waveforms!!!
- Optimize memory usage: Don't allocate more than MAX_SAMPLES_ST for blocks which only get downsampled audio. So only allocate a few things bigger.
- Change tone generation FM enable/disable and order.
- VST multiple instances fails - Tested and works fine. Ignoring unless I'm receiving a better report. Note: 32 bit too many instances can crash due to the 2 GB limit. Max number is now 3, used to be 6 so some optimization could be useful.
- Make VST window bigger
- Fixed Quality slider bug introduced in previous beta
- Fixed jumping pilot and RDS effect on some 'Ignore frequencies above' frequencies.
- Sometimes the top and bottom waveforms run at different speeds when Ignore Frequencies Above is enabled.
- Make Chain block (small size) based - Partially done
- Declipper display is broken. Even without Ignore Frequencies Above. Ok upto 100 ms. Also broken in 7.70!!! Only if samplerate > 48 kHz, and when switching between sizes, upto 100 ms everything is fine (even if no audio is playing so no refresh of the data occurs), so the bug is in the displaying code. -> Was a shift error, fixed.
- Again, fixed noise level jumps and spike at Ignore Frequencies Above frequency.
- Clipper issues Leif / Wolf Stahl (probably the same thing) - Should be fixed now. - Waiting for reply Wolf- Check new clipper highs
- Remove "Take some shortcuts" under CPU, probably broken! And has not much effect anyway. -> Hm, no, must have been in use for the tests. Ugh... TEST to check what is better: ON (which will probably allow more sounds through) or OFF. -> Actually it does seem to work AND allow more highs through, but I don't know if that's a good thing - more tests needed!
- Added lowpass filter after clipper in non-composite mode.
- Fixed problem with click sounds (reported by DJ_DOGGY). Reduced output level by 1% - you can safely increase modulation by 1% if you're using an output that's affected by this (should only be FM signal inside a plugin). If you're using the stand alone version, make sure to set the output level to the sound card no higher than 99% (-0.1 dB).
- Fix downsampling and Quality slider problems: Lower Quality setting
- Attempt to reduce effect on volume of using Leif's clipping method.
- Fix DJ Doggy's reported errors (19 kHz, junk around tones).
- Ignore frequencies above a specific frequency -> Should lower TOTAL CPU load by another 10-20% (now fully implemented except at lower Quality settings)
- Fixed the lowpass bug that was introduced in 009. Although it has probably always been there! As a side effect, the output is also slightly louder (about 0.02 dB) with no negative effects.
- Fixed distortion introduced in 009/010. Extra highs are still there though! See new 'Sparkling highs' section under Advanced Clipper -> Sound
- Fix optimizations
- Fix code #warnings
- Some small optimizations
TO DO 7.71:
- Synchronization is broken in 008 (was ok in 007) - Don't see it! Is anyone still seeing this? - No response, assuming ok.
- Fix Mac VST version (not recognized apparently) - Tested 025 in Reaper, works fine.
- Remove About photo
- Add presets
- Change default preset to something useful
- Change version number to 7.71
- Release
TO DO 7.72:
- BS412 boost-at-start
- Add delay (in samples) for one of the two MPX channels to send audio to allow synchronization of 2 transmitters which use the same frequency. (John Markis)
- Add impulse response import function!!!
- Noise learning Micha
- EQ with 'standard' sliders.
PostPosted: Thu Aug 06, 2015 7:16 am
Sorry for the quenstion right now but...
What means this impulse response import .... What this one will do ?
PostPosted: Thu Aug 06, 2015 4:49 pm
I was going to ask this very same question.
PostPosted: Thu Aug 06, 2015 9:40 pm
Bit hard to explain, best it to wait.
PostPosted: Fri Aug 07, 2015 5:05 pm
Stereo Tool 7.71 BETA026 - Getting close!
Windows stand alone: http://www.stereotool.com/download/ster ... 71-026.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-026.exe
Windows 32 bit VST: http://www.stereotool.com/download/vst_ ... 71-026.dll
- Add presets
Risky change.
- Fix optimizations
TO DO 7.71:
- Release
TO DO 7.72:
PostPosted: Fri Aug 07, 2015 7:04 pm
Indeed - getting close!
No more 'about' photo of you Hans? :lol:
PostPosted: Fri Aug 07, 2015 7:35 pm
It will be replaced with the ST chick of the month! :mrgreen:
PostPosted: Sat Aug 08, 2015 2:31 am
Hans,
Looks like the declipper detection isn't displaying on the left meter on the main Processing page, when enabled. No fun red lines.. :(
PostPosted: Sat Aug 08, 2015 5:14 am
It looks like the delay needs more attention that originally thought I guess. :oops:
PostPosted: Sat Aug 08, 2015 11:59 am
Hello,
I found (hope only a GUI) bug. The left input channel seems has some input gain but as you can see in the attached picture this function is not active. In beta020 it was OK, I saw it first in beta023 but 021 and 022 not tested.
