What about distortions, harmonics, lack of punch, voice vibrations, lack of good bass ... wich are all not so present in Orban processor ?
Do you have examples of that? I only have the Orban files that someone (you?) posted some time ago, and there:
- Stereo Tool has considerably less distortion - at least for the 'difficult' sounds
- Bass level is the same as in the current 'FM Transmitter (Europe)' preset (compared both by listening and by measuring the frequency content).
- As far as I have checked, I don't really notice any difference in punch - in which track(s) do you hear this? And the volume drop for loud 'S' sounds is now less in Stereo Tool than in the Orban samples (a few BETA's ago that was the other way round).
- What's the difference between distortion and harmonics? Or do you mean 'bass distortion' by distortion?
- Vibrating voices are not present in the examples that I checked. Do you still get those? Because I thought they were nearly completely gone since I added the phase rotation filter.
It's hard to explane .. but..
ST works totally different then Orban or Omnia and i'll put Breakaway on this list.
Major differences:
- ST have more bands (almost half more) - That can be problem
- In my oppinion ST BASS Clipper is in wrong place. - Should be right before final limiting. In relation of that, others have their Distortion cancelled/controlled clippers, wich again in ST case.. Main FM clipper is again too soft.
Clipper shuld be zero-attack/release with time limiter with a ratio of infinity-to-one. (
OMNIA)
In Clipper like that Intermodulation distortions occures. But, again this is not case in ST because ST clipper is not like that. It's more like simple limiter! So it indicate that this voice vibrations (caused by low-bas sounds) are not in clipper .. but more it's in limiters or multiband.
My oppinion is, when you can play any track thru ST (in FM mode) with only Hard Limit and Composite Clipper ON.. Than it will be good.
- Again look at Breakaway core:
There are big difference if we compare it with ST.
- There is AGC with sidechain EQ (something i requested erlier)
- There are compressors feed back/forward
- There are LA limiters in multiband bands
- Ratio settings for MB bands .. etc...
So Orban will never sound Like ST or Breakaway or otherwise... But afaik, orban, omnia and breakaway have much closer routines for processing.. much closer then ST.
track example:
Clear voice vibrate caused by rate of bass sound - much more in bass presets.
http://www.mediafire.com/?c4qhyz07ps8zc4t
Interesting is in ST that in some cases when you puch Loudness MORE... there is less distortions like this vibration. Bu then other distorions are present. So like Loudness don't know when and how much is needed to limit/clip that bass..
I'll upload another track with very nasty bass wich is sometimes causes voice distortion even in breakaway, but in ST is very obviously.
