Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 129 30 31 32 3359 Next
PostPosted: Mon Mar 28, 2016 9:58 am
@RodeoJack - this was mentioned a little earlier in the thread. Not sure if Hans has finished sorting it out yet.
Also busy making it possible to register the Delossifier...
Edit: I can now manually generate Delossifier licenses. Now I just need to think of a price :)
PostPosted: Mon Mar 28, 2016 5:47 pm
I recall seeing that. Thanks, "2Sense". I'd like to run it through my station, but would rather not hear the beep it says it plays!
PostPosted: Tue Mar 29, 2016 12:10 pm
Do you plan on including the old license keys that contain the Declipper to use the Delosifier?
And, if not, how much it will be for the update?
p.s. is this right?
PostPosted: Wed Mar 30, 2016 6:20 am
I'll be in Poland and France the next few days so if I'm slow to respond you know why...
PostPosted: Wed Mar 30, 2016 6:21 am
Still need to decide what to do with the Delossifier but I'll probably arrange something (discount) for the people who are participating in this thread.
It doesn't make sense yet to put it on the normal payment page since it's not yet available in a release version.
PostPosted: Fri Apr 01, 2016 1:59 pm
Hmm, am I the only one who finds the "mouse movement over ST window raises FPS dramatically causing CPU spiking and thus possibly interrupts audio processing leading to buffers possibly running out" annoying? Could it be optional? (yeah, I'm running FM tests (trial version) on old i5-660)
PostPosted: Sun Apr 03, 2016 5:13 am
7.85 BETA052
Windows stand alone: http://www.stereotool.com/download/ster ... 85-052.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-052.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-052.dll
CHANGED:
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Absolute Highs: CRASH!
- Absolute Highs: Optimize performance: Check log()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly?
7.85 but after NAB:
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem?
LATER:
- O skin
PostPosted: Sun Apr 03, 2016 2:37 pm
I've tried the latest version. in this the spectrograms at the absolute highs are cut. see the screenshot.
PostPosted: Sun Apr 03, 2016 6:30 pm
Guys, i am backkkkkkk!! ....and i m very very excited with the latest version of Stereotool .
It is better than Omnia 9 or 11 ( with latest firmware ).
And i can prove it ,
I can also prove the 10 dbr of loudness on 75 KHz legal modulation !
10 dbr !!!!!!!!!!!
You can hear the FM radiostation at 320 kbps ( for no overshoots ) private stream.
On FM it is even more loud becuse of Advanced Clipper effect.
So, imagine how more loud it is :)
Just crazyyy!
http://stream.cretanservers.gr/fmbroadcast
mp3 320 kbps PRIVATE TESTING link.
I am planning to sell massively the ...loudest preset on the planet when Hans makes this possible.
( 900 euros is ok )
p.s.
The reason of this price is THE LOUDNESS .
You can modify the preset for less distortion but you cannot distribute it or re-sell it as is or modified.
PostPosted: Mon Apr 04, 2016 10:42 am
That stream is not from tuner. We want tuner :)
