Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 129 30 31 32 3335 Next
PostPosted: Tue Aug 04, 2015 4:31 pm
BETA 24A did not work for me (non-FM, non-ASIO, 192KHX sample), spoken word came out as a serious case of "Alvin and the Chipmunks" = high pitched squeaks. Never heard this in BETA20.
BETA 23 is what I reverted back to, sounds fine.
Bob Hawkins' Loud and Clear is my go to but affected all presets.
PostPosted: Tue Aug 04, 2015 5:11 pm
I can confirm this. 48khz works. Anything higher is broken.
PostPosted: Tue Aug 04, 2015 6:44 pm
Strange, beta24 works fine for me. i'll test more..
edit: Seems there IS problem. Big drops when i use full FM preset and normal output.
PostPosted: Tue Aug 04, 2015 7:06 pm
Why you use 192 Khz for input ? You already have max 48 Khz of input music ? What is the idea to resample the "garbage" . It stays garbage .
Changing the sample rate is "clear" the issue because program REFILLS the buffers. After another night , you will get the same . Try it !
Appreciate your thoughts DJ-DOGGY. I'm using 192kHz for MPX (FM) generation purposes. While I understand what you are saying, I'm still not convinced that this is 100% a buffer issue. I might be wrong though!
@2sense: I've browsed through your posts and listened to the recording that you made; it seems as if for some reason the number of samples sent to the output is lower than the number of samples that comes in. Except that I would expect that you would see it in the buffer filling, and according to your description that's not the case (or does it get less full over time?)
How big did you set your ASIO buffer?
The buffer doesn't really change much in size from what can remember. FM output buffer is 0.250s and NO is 0.550s
@2sense: 2 more questions:
1. Does it also happen if you disable 'Ignore frequencies above'?
2. Can you send me your .ini file? Other people (except Cornyman) aren't complaining about this so I'm unsure what's happening - there may be something special in your settings that almost nobody else uses. I don't know what that something could be though.
If you check the clip I sent you, right near the end, things clear up - this is when I turned off 'ignore frequencies above', when I reactivated it the really bad glitching returned.
I'll send you my .ini file - I hope that things are somewhat the same as when I tested - I know I mucked about thereafter.
Don't know if this is related - I am also monitoring a deemphasized version of the FM using NO.
Hans - have you any idea why the buffer seems to fill / un-fill at different fluctuation frequencies with 'ignore high frequencies' enabled or disabled?
Also - when you enable auto-restart for restart on buffer issues - is this designed to generate an exception for the restart?
PostPosted: Tue Aug 04, 2015 9:31 pm
Ok, first the good news: I think I found the cause! In fact it seems to be a bug that has been there for years, for some reason (I don't understand why) it was apparently triggered by the 'Ignore frequencies above' setting.
Different fluctuation: That could be because the CPU usage is less stable (it collects a bigger block of data before it starts to do something). What did you set the sound card ASIO block size to? If it's small the effect should be less.
Auto-restart: I think so, because the whole issue shouldn't happen so I do want to show a notification; if you come back after a few days you at least know that something happened.
PostPosted: Tue Aug 04, 2015 10:02 pm
Stereo Tool 7.71 BETA024B
Glitches (2sense, cornyman) and >48 kHz sample rate issues in stand alone version should be solved now.
Windows stand alone: http://www.stereotool.com/download/ster ... 1-024B.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-024.exe same as before
Windows 32 bit VST: http://www.stereotool.com/download/vst_ ... 71-024.dll same as before
- Reduce memory usage further (check all MAX_SAMPLES_44K arrays including SS and multi_samples) - Effect is small (about 0.5 MB) - not worth the effort.
- Check all #pragma messages.
- Fix >48 kHz Normal Output issue in stand alone version.
- Fix reported glitches/hiccups?
- Optimized Stokkemask exciter code
- Optimized output to lower sample rate sound cards (includes plugin hosts). Overhead (CPU load even when all processing is disabled) is greatly reduced. Risky change.
- Tested a large number of other small things (there were a bunch of remarks that I placed throughout the code, and most of them are removed now).
- Fixed FM tilt correction GUI issue.
- Exception reported by DJ_DOGGY fixed.
- Make OldSamples buffers (and potentially others) dynamic to save memory - Currently allocating 85 MB just to display waveforms!!!
- Optimize memory usage: Don't allocate more than MAX_SAMPLES_ST for blocks which only get downsampled audio. So only allocate a few things bigger.
- Change tone generation FM enable/disable and order.
- VST multiple instances fails - Tested and works fine. Ignoring unless I'm receiving a better report. Note: 32 bit too many instances can crash due to the 2 GB limit. Max number is now 3, used to be 6 so some optimization could be useful.
- Make VST window bigger
- Fixed Quality slider bug introduced in previous beta
- Fixed jumping pilot and RDS effect on some 'Ignore frequencies above' frequencies.
- Sometimes the top and bottom waveforms run at different speeds when Ignore Frequencies Above is enabled.
- Make Chain block (small size) based - Partially done
- Declipper display is broken. Even without Ignore Frequencies Above. Ok upto 100 ms. Also broken in 7.70!!! Only if samplerate > 48 kHz, and when switching between sizes, upto 100 ms everything is fine (even if no audio is playing so no refresh of the data occurs), so the bug is in the displaying code. -> Was a shift error, fixed.
- Again, fixed noise level jumps and spike at Ignore Frequencies Above frequency.
- Clipper issues Leif / Wolf Stahl (probably the same thing) - Should be fixed now. - Waiting for reply Wolf- Check new clipper highs
- Remove "Take some shortcuts" under CPU, probably broken! And has not much effect anyway. -> Hm, no, must have been in use for the tests. Ugh... TEST to check what is better: ON (which will probably allow more sounds through) or OFF. -> Actually it does seem to work AND allow more highs through, but I don't know if that's a good thing - more tests needed!
- Added lowpass filter after clipper in non-composite mode.
- Fixed problem with click sounds (reported by DJ_DOGGY). Reduced output level by 1% - you can safely increase modulation by 1% if you're using an output that's affected by this (should only be FM signal inside a plugin). If you're using the stand alone version, make sure to set the output level to the sound card no higher than 99% (-0.1 dB).
- Fix downsampling and Quality slider problems: Lower Quality setting
- Attempt to reduce effect on volume of using Leif's clipping method.
- Fix DJ Doggy's reported errors (19 kHz, junk around tones).
- Ignore frequencies above a specific frequency -> Should lower TOTAL CPU load by another 10-20% (now fully implemented except at lower Quality settings)
- Fixed the lowpass bug that was introduced in 009. Although it has probably always been there! As a side effect, the output is also slightly louder (about 0.02 dB) with no negative effects.
- Fixed distortion introduced in 009/010. Extra highs are still there though! See new 'Sparkling highs' section under Advanced Clipper -> Sound
- Fix optimizations
- Fix code #warnings
- Some small optimizations
TO DO 7.71:
- Synchronization is broken in 008 (was ok in 007) - Don't see it! Is anyone still seeing this?
- Fix Linux version (someone mentioned that it crashes after a few minutes, on Ubuntu 14.04 - re-check with Valgrind) -> Done, found a few issues, Valgrind shows 0 errors now. I will run a Linux build so people who complained can check it again.
- Remove About
- Add delay (in samples) for one of the two MPX channels to send audio to allow synchronization of 2 transmitters which use the same frequency. (John Markis)
TO DO 7.72:
- Add impulse response import function!!!
- Noise learning Micha
- EQ with 'standard' sliders.
PostPosted: Wed Aug 05, 2015 12:19 am
Strangely two messages were removed.. I understand that the rant isn't what is wanted here but could you please tell when one has crossed the border (if they were removed by moderator)?
PostPosted: Wed Aug 05, 2015 1:06 am
I haven't seen anything?
PostPosted: Wed Aug 05, 2015 1:29 am
Omg.. So embarrassed here, this is what happened: I thought that I clicked the last page from the thread listing, but I seems that I pressed the topic itself,
which takes you to first page.. So I thought that the messages that unnamed and Slawomir B. wrote on the first page (which I thought was the last page, since they weren't showing here!) were removed from this page, which of course isn't the truth.
Carry on :D
PostPosted: Wed Aug 05, 2015 7:32 am
Thanks for the feedback - I think my ASIO buffer is set at 800 samples.
As a follow-up test, I ran Beta 024B (bug fixed?) overnight again to see if I would still get the bad glitching in the morning. Seems fine now - no glitching noticed!! :)
Hope that others will give feedback also.
