Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 476 posts ]  Go to page Previous 129 30 31 32 3348 Next
PostPosted: Sat May 02, 2015 7:27 pm
Bandmix still before limiters.
I thought I had fixed that. Will check it tonight.
PostPosted: Sat May 02, 2015 7:53 pm
are you shure, that you included the gate in the VST version? i looked on every place for it, but i cannot find it anymore. :roll:
PostPosted: Sun May 03, 2015 2:50 pm
Ow. I think I didn't even build that one - it should have been a broken link but I guess the new compiler/development environment isn't removing the file.. Sorry! I will build an update!
PostPosted: Sun May 03, 2015 2:58 pm
I checked and it works as it should here. Please tell me what you are seeing... If I increase Band Mix, the whole audio (including limiting) comes out louder here.
PostPosted: Sun May 03, 2015 11:23 pm
I dont see that. I see peek level stays ~same.
For gates/freeze would be good some small red boxes on top of every band. Lights up whenever freezing. Currently they are white bars, and nothing for limiters.
PostPosted: Mon May 04, 2015 12:00 am
Hm, I'll build and upload the latest version again, maybe something went wrong with the update.
Limiters are also properly visible now - but I need to find a better way (your suggestion sounds good) to display gating.
PostPosted: Mon May 04, 2015 11:17 am
BETA 761-033
Windows stand alone: http://www.stereotool.com/download/ster ... 1-033A.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 61-033.exe
VST 32bit: ----://www.stereotool.com/download/vst_stereo_ ... 61-033.dll (NOT AVAILABLE)
- Improve limiter GUI display
- Don't allow Threshold values below 0.5 dB (singleband, others are already ok)
- Optimize gating (turn off if not needed)
- Made 'limit before compress' again, switchable
- Add Gate for new compressor release (also GUI)
- Band Link etc. does not work in 3-band mode, and it should for AGC-type behavior.
- Simplify interface (remove Oil Speed Adjustment sliders etc, move some things to Extreme Tweaker mode)
- Adjust limiter level for Band Mix
- Fix 'Load default values' question for MB #bands change
- Make Shape value small for high speeds - TO BE DONE: Test if the border value is chosen correctly (shape effect is deminished below 40 ms, reduced to '1' for 0 ms; not sure if 1 is low enough?)
- Fixed some more GUI crashes. They should all be fixed now...
- Check if audio is still the same as in older versions (!)
- Set MB2 default settings ok for NAB demoing (very fast)
- Fixed some (but not yet all!) GUI crashes
- Improved CPU performance a bit, on multiple places (clipper, GUI).
- GUI crashes from previous beta's are probably fixed (?)
- Changed some GUI things (for big displays)
- Small performance optimizations
- Limiter behavior visible in meters
- Fixed MB ITU mode.
- Fixed Median display in Analog mode
- Made final SB compressors switchable, parameters are also shared between analog and digital now.
- Added limiters to singleband and multiband Analog compressors. Warning: Meters are not yet visible in the GUI! Which makes it kinda difficult to setup (you can use Monitor to see the output of a single band and then adjust the limiter setting).
- I fixed something in the GUI but I had a situation where I couldn't start it earlier tonight so it's probably not completely fixed yet.
- Some settings from the 2nd MB overruled the 1st, causing all kinds of effects. That has been fixed now, and I verified that the audio of Digital mode in the 1st MB is (nearly) identical to that of BETA761-016 (nearly because in 016 the frequencies still were 10% off). New quickly put together preset (NICE2) attached.
Fix MB frequency band shift (10%, since 7.51 or 7.60) - Appears to be gone but I don't remember fixing it (!)
Fix RDS time issue! viewtopic.php?f=6&t=5941&p=28209#p28209
Added 2nd Multiband compressor! Example preset is attached below. To me, turning it off makes the sound boring/empty. I think this is exactly what some people were missing in Stereo Tool. And with 2 steps the audio is also more consistent than before. RMS/ITU based preset would probably be even better... To increase or decrease the effect, adjust the Density slider of the 2nd Multiband compressor!
- Optimized CPU load. CPU load now strongly depends on the settings, for the settings that I posted earlier it's now less than half that of Digital mode! On my system it went down (single core mode, CPU load on that core) from 12.3% to 2.5%! (Again, depending on settings). Digital uses 9.1%.
- Merged more parameters (Peak vs RMS setting) with old ("digital") compressor.
- Slower Release speed in Analog compared to Digital
- Removed Shape Enable settings.
- Fixed Knee in Analog mode
- Fixed Aggressiveness slider behavior for Analog (!), made it behave the same as Digital mode (acts only on release speeds).
- Merged more parameters (Attack Time, Release Time) with old ("digital") compressor. Adjusted numbers in Digital compressor to match the (correctly calculated) behavior in Analog mode.
- Merged parameters (threshold, knee, ratio, feedback, channel separation, band mix) with old ("digital") compressor, I noticed that I was switching back and forth all the time to copy settings, so this seems easier. Threshold is now also displayed in dB's.
Made Multiband version of the new compressor! Choose 'Analog' mode to switch to the new one. See attached preset for an example!
- Made new Traditional Peak mode which behaves more like normal Peak.
- Added Lookahead, removes huge spikes at start of attack for fast attack times and reduces IMD.
- Fixed Ratio behavior
- Fixed 'Density Drive' slider in Analog mode
- Fixed no audio with certain combinations of filters
- Fixed a filtering issue in the Digital compressor (!) when using Density Drive > 1.00
- Added lowpass filter to control signal to smooth out bad effects and remove distortion
- Added ITU-1770 mode to reduce pumping and improve level control
- Added Channel separation
- Rewrote all code
- Fixed Ratio
- Channels are not processed separately (wasn't the case before, and that was a bug)
- Fixed attenuation display
- Attack and Release times must be set to half the numbers of the previous beta's. Oil change speed must be doubled.
- Restored old Shape behavior from version 009
- Replaced 'Nonlinear Release' by 'Exponential Release', which works better and only needs 1 parameter. Use this to go up FASTER if you're down DEEPER.
- Added Ratio
- Added Feedback mode
- Fixed out-of-control behavior for certain extreme settings
- Fixed some more weird behavior things if the difference between Attack and Release is REALLY huge (behavior was bumpy and caused clicking sounds).
- Known issue: both Shape On settings must be enabled. I will probably remove them in the next build anyway so I'm not going to fix it.
Fixed a lot of bugs, will type the details here later. Oil Temperature is now in % and didn't work properly before. PLEASE LOAD THE DEFAULT SETTINGS for the new compressor or it will sound horrible.
Changed Attack Time, Release Time, Attack Speed Threshold, Release Speed Threshold to understandable values. Made 1.0 the 'standard' behavior for Shape.
- Added smoothing to oil temperature behavior for both attack and release.
Added Oil temperature behavior which was missing from my automatic (hydraulic) door model. Will explain below...
- Added another Peak mode slider in "New Singleband". The old one (from yesterday) works mainly on release, but in some cases the volume didn't go down fast enough on a loud sound. The new one works mainly on attack (higher value makes attack continue AFTER a peak.
- Changed Peak mode behavior in "New Singleband".
- New Singleband: Split Speed into Attack and Release Speed
- New Singleband: Made Attack and Release Speed Threshold relative to Speed - so you don't need to adjust it to change the shape.
TO DO COMPRESSOR:
- Improve gate GUI display
- Make after-AGC SB compressor switchable as well
- OPTIMIZE LIMITER
- Freeze only for all bands combined. Still not sure if this is really a good idea...
- Maybe add downward expander
- Add Drive parameter for each MB band
TO DO:
- Fix delay of Delossifier in display
- EQ with 'standard' sliders.
- Add RDS control via VST typedef VstIntPtr (VSTCALLBACK *AEffectDispatcherProc) (AEffect* effect, VstInt32 opcode, VstInt32 index, VstIntPtr value, void* ptr, float opt); for Bernd N
- Improve Dequantizer by combining data from different block sizes
- Add HD delay (upto 10 seconds? Check Matt Aaron's drawing). Also finally make resampler for normal output to fix 2 output on different sound cards problem. Move Resample setting from input to output. Let's ignore using 2 inputs for now...
PostPosted: Mon May 04, 2015 1:11 pm
Hans,
I just downloaded Beta 33 and it has the same date and time stamp, and filesize as Beta 32.
C.
PostPosted: Mon May 04, 2015 3:36 pm
Hans,
C.
Woops! The DSP is updated properly but for some reason the .exe isn't....
PostPosted: Mon May 04, 2015 4:28 pm
- In last 2 betas i noticed much slower MB when i switch from digital to analog.
If i want to make them faster it works so strange.
- exception whenever freeze sliders are touched
- Freeze should be freeze. No speed no nothing its simple freeze with defined threshold.
- Freeze should be not per band. Just no need for that. It's enough to be at MB input, always ON with just one simple thresh slider.
