Well for FM all freqs from 0-to almost 500Hz should be strictly "Clipped/Limited" to some lower value (e.g. 90-95%), to leave room for rest of sound. Orabn, ... ,does that too.
Currently I clip the freqs below 100-200 Hz to 73%. Are you sure that I could limit it to 90% if I go upto 500 Hz, or would that be an extra step?
Playing with this last days ...
Not possible with StereoTool!
I maked to 'clip' (not limit) freqs from 0-400Hz, and that is, let's say ok, but if i set level more then 70% for these freqs there is voice vibrations and other distortions to sound caused by lows. Orban can do this with 95%! level of this freqs. because they have sort of compensated, canceled, probably for that band - clipper, wich cancels lows in that range to pass thru upper band (400Hz+). pfff.
