Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 129 30 31 32 3376 Next
PostPosted: Fri Mar 09, 2018 10:21 pm
Yes in constant tones, not in dynamic content.
PostPosted: Fri Mar 09, 2018 10:25 pm
All my testing so far has been with dynamic content. I haven't even checked tones yet. It tracks very well if you just flip the mode and slow the releases down by 20%.
PostPosted: Sat Mar 10, 2018 9:50 am
Stereo Tool 8.55 BETA037
Windows stand alone: http://www.stereotool.com/download/ster ... 55-037.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-037.exe
VST: http://www.stereotool.com/download/vst_ ... 55-037.dll
- Fix Basstardizer crash
OLDER CHANGES:
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Check Auto EQ behavior on sudden level changes, and initial Auto EQ behavior after startup
- Optimize new compressor modes, create separate "NICE_MODE" code paths, put all values in a LUT.
- Test NanoPi
- Classical preset
- NAN seen when switching to new compressor mode which also doesn't get recovered - silence afterwards. (Peak mode recovers it though).
- New skin
- Is pre AGC affecting audio levels? (With BS412) -> Not specifically for BS412, but it slightly reduces the level even if set a lot higher. Probably needs some offset.
- Aanvraag uren
- AM streaming output
- Add AM presets
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
Important: The CPU load is really high right now. I will optimize it later.
Also important: You can't just enable this new mode and expect everything to be fine without changing the settings. For small level differences there won't be a difference, but there will be for big differences. You'll definitely notice the slower attack on big level jumps.
PostPosted: Sat Mar 10, 2018 10:41 am
Thank you. :ugeek:
8.54 -> 8.55 is shaping up to be a pretty major update. Maybe it should go to 8.60 for the final version. :mrgreen:
PostPosted: Sat Mar 10, 2018 10:49 am
What's that about? Analog wasn't affected?
PostPosted: Sat Mar 10, 2018 10:49 pm
No.
PostPosted: Sun Mar 11, 2018 3:36 am
The updated Basstadizer seems overly "thumpy" at the default levels. :shock:
PostPosted: Sun Mar 11, 2018 3:38 am
You noticed too. Man is that ever powerful. I reduced strength to -12 and it's still noticeable. I'll be tweaking for a while!
PostPosted: Sun Mar 11, 2018 3:58 am
It's less noticeable in some tracks, more in others.
I like the effect, but then again I feel it's changing the original too much. It is called the Basstadizer after all.
I feel like the effect strength range should be broader, with a default setting that's maybe about 1/4 to 1/3 as powerful as it is now.
I'm at these setting currently :?:
PostPosted: Sun Mar 11, 2018 4:01 am
I lied, I'm at -9.90dB and it's totally usable. However, if I knew what these controls did, I'm sure I could customize a lot more!
