Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 1 2 3 4 5 635 Next
PostPosted: Thu Jun 25, 2015 12:36 am
But there are other processors as well and not only i7 47xx. And another example i can run two instances of stnone for all the audio processing and another to do the fm things with no problem. But if try to use only one st i can't because the cpu single core performancee is not all that great. But if you can add one more thread especially for the clipper that would be nice.
My radio station
http://amradio.ddns.net
PostPosted: Thu Jun 25, 2015 7:47 am
I am with AMD Athlon II and my own preset (not build in) and it`s not heavy.
When all options are to "ANY core" - it uses both cores with almost same load .
When i turn into Core0 all the options - it goes to first core and the other is free.
When i turn back to "ANY" - it still uses the last choosed. But when restart the program , it again uses both cores with balanced load.
PostPosted: Thu Jun 25, 2015 10:19 am
That is a problem that windows have with threading. In reality ST is NOT using all the cores equally but windows make the threads jump from core to core so fast that the task manager thinks it is an equally divided workload but it really isn't. And that is not beneficial because you have one core that will do all the work again for a small period of time and the just switch to another core and so on.
My radio station
PostPosted: Thu Jun 25, 2015 10:55 am
On my laptop I can run any of the built-in FM + composite clipper + Stokkemask presets without any issue on a SINGLE core - so not even 2 - with plenty of headroom. That's on a laptop i7 4710 at 3.1 GHz. So... A 4790 desktop i7 at 4 GHz should really have no problem at all running this, unless something is very wrong somewhere.
Sorry, there should be nothing wrong.. I maxed every CPU settings in ST to get to that result. 4790K has 4 physical cores, and two virtual cores out of 8 were maxing out with the ultimate max settings. Of course there is a chance that some real 8 core processor will perform worse since the singlecore (or dualcore/dual thread) performance drops.
PostPosted: Thu Jun 25, 2015 1:24 pm
ST 7.70 on linux:
115% cpu for that process. Using everything except FM.
This is on a AMD Phenom(tm) II X2 555 Processor.
PostPosted: Fri Jun 26, 2015 12:47 am
Stereo Tool 7.71 BETA002
Windows stand alone: http://www.stereotool.com/download/ster ... 71-002.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-002.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 71-002.dll
Some small fixes and a big code rewrite to improve reusability.
TODO 7.71:
- Fix CPU measurement for high loads (jumps to 95% for unknown reason).
- VST multiple instances fails
- Make VST window bigger
- Noise learning Micha
- EQ with 'standard' sliders.
TO DO WITH LEIF:
PostPosted: Fri Jun 26, 2015 11:12 am
I have big CPU load increase .
About 6.5% more according to ST red bar.
PostPosted: Sat Jun 27, 2015 1:42 am
DSP, Stand alone, VST?
Edit: Ah, a small part of the code wasn't included in the CPU load measurement and now it is. So that could be it... Can you check the actual CPU load using another tool (such as Task Manager)? On my pc I see no difference there, but I do see a difference in the red bar!
PostPosted: Sat Jun 27, 2015 7:28 am
It`s for Stand Alone .
I check in task manager , but looks like nearly no difference . Strange
PostPosted: Sat Jun 27, 2015 7:52 am
In the MB2 you can not select the type?
by GAP
"Less is More" (Bob Katz)
