Post new topic  Reply to topic  [ 80 posts ]  Go to page Previous 1 2 3 4 5 68 Next
 Post subject: Re: Stereo Tool 7.60
PostPosted: Sun Jan 18, 2015 11:57 pm
When the Bypass is enabled, Phase Delay Graph is active. ;)
by GAP
"Less is More" (Bob Katz)
PostPosted: Mon Jan 19, 2015 4:33 am
viewtopic.php?f=14&t=5863&start=10#p27768
PostPosted: Mon Jan 19, 2015 2:21 pm
Sorry :lol:
by GAP
PostPosted: Mon Jan 19, 2015 9:01 pm
Is someone else see at the Taskman a creeping RAM increase (per second) when using the VLC as input ?
My increase is exactly as how much is the stream in kb/s .
Is this like it should be , normal ? This means if i stream 100 hours or 200 , my RAM will be full ? May be the runtime crash is related
EDIT: it stops fulling the RAM after a few MBs .. 3-4 megabytes.
PostPosted: Tue Jan 20, 2015 2:27 am
Must be VLC that's doing that, especially if it's the amount of memory in the stream.
PostPosted: Tue Jan 20, 2015 3:13 am
hi can yo make on stereo tool streming i mean stereo tool + radio streaming togather like sonos 4 but sonos 4 no good sounds :( when ı put ip number and port and password after radio streaming start do you understan me ?
this good i dia
PostPosted: Tue Jan 20, 2015 4:11 am
this good i dia
Hi evrenselFM, :)
If you are struggling with English at all, you can always just go to https://translate.google.com/ and translate your usual language to English and then paste it here if you find that easier. :D
PostPosted: Tue Jan 20, 2015 12:07 pm
With Google translate is the same as sound.
garbage in = garbage out.
PostPosted: Tue Jan 20, 2015 12:51 pm
evrenselFM like Mr Bean :D :lol:
http://www.radiomaharaja.com/
PostPosted: Tue Jan 20, 2015 1:15 pm
this good i dia
You could use VLC streaming, it's not that simple but it works. I want to add different options soon (but I'm going to hire someone to do that, don't have enough time to do it myself).
