Post new topic  Reply to topic  [ 41 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Wed Feb 10, 2016 1:34 am
A few pics of Serbian radio stations, made by my friend in Belgrade.
http://i.imgur.com/CfMVtq5.jpg
http://i.imgur.com/eVxceMN.jpg
http://i.imgur.com/vlffj4C.jpg
http://i.imgur.com/Pxdh6Et.jpg
Video will soon follow!
http://i.imgur.com/Z6EPw2G.png :)
PostPosted: Wed Feb 10, 2016 8:35 am
Hello everybody!
I'm "the guy" who made those screenshots posted above. Unfortunately I don't have (or I can't see it) an option for 150kHz bandwidth, here is a screenshot from HDSDR:
Like this:
So - samplerate stays 192 kHz, but you need to narrow FM bandwidth to 150 kHz (the closest I can come with HDSDR is 150.977), otherwise the mpx output is about 20% too low.
OR
compensate for the 20% offset (in mpx tool for example). By compensating the signal in MPX tool itself you can actually listen and measure slightly overmodulated signal accurately.
Here the measurements I get from one radiostation that has solid signal in my area:
150 kHz BW - pilot 9.5% (+/- 0.1%)
192 kHz BW - pilot 7.5%
And I'm pretty sure 9.5% is accurate
Bojcha used different method, with modified tuner that has mpx output - it's the most accurate way of measuring signals, provided you know how (and are able to) calibrate the whole system, including line input in your soundcard.
PostPosted: Wed Feb 10, 2016 7:16 pm
Thanks a lot!
Totally missed that, as a matter of fact it wasn't even visible to me, I had to click on AM then back to FM to get that slider, and as you said the closest bandwidth is 150.977
I'll post new pictures in a few days!
PostPosted: Mon Feb 22, 2016 1:18 pm
I should like to thank Slawomir for sending me a one USB dongle with RTL2832!
Now i can play with it too :)
Thanks Slawo!
PostPosted: Fri Feb 26, 2016 11:29 am
Oh dear :) No problem! :D
PostPosted: Mon Mar 07, 2016 5:34 pm
From rtvforum.net
http://www.rtvforum.net/thread-59-post- ... #pid169912
PostPosted: Sat Mar 12, 2016 7:46 pm
The promised videos are here! Both videos are password protected - the password is rtvforum.
Domo-kun sent them to me via private message. :)
Play 92.5: http://www.dailymotion.com/video/x3xg55u
Radio S 94.9: http://www.dailymotion.com/video/x3xg5ob
Both videos are showing speech segments. I don't understand why bandwidth increase does nothing to the distortion in the Play 92.5 video?
PostPosted: Sat Mar 12, 2016 9:05 pm
Here is one more, Radio Beograd 1 on 95.3MHz, same password...
http://www.dailymotion.com/video/x3xh5u9
PostPosted: Mon Mar 14, 2016 12:11 pm
Might be multipath - please note how asymmetric the signal is. Maybe received signals were overlapped with the reflected ones. I've seen same while testing the receiver between tall buildings.
PostPosted: Mon Mar 14, 2016 2:01 pm
92.5 and 94.9 are coming from the same transmitter location with similar power, yet 94.9 has no distortion (except that induced by Optimod) so I doubt it's multipath. About the asymmetric signal, you think of the 95.3 signal? That's because 95.3 is running without audio processor, so there is nothing to symmetrify asymmetric voice.
