Does St 7.45 003 need more cpu that 7.42????
No, it should be roughly the same. Do you see an increase?
Hans I am running ST on a very old single core cpu pc and with 7.42 i have 85% load but with 7.44 wich i've tried in the past i had 100% and it was gliching...
Thanks Hans
Edit : with the same preset...
Ah. Single core must be the important thing here I think. I've heard something similar from one other person. I've done a measurement and the latest (7.45 beta) version has exactly the same CPU load as 7.42 (I've improved the limiters which should cause some increase, but it seems so small that I cannot measure it here).
Can you tell me how high the "Percentage of time in processing" meter is? It's under Configuration -> CPU & Latency. Please set the GUI update speed to 1% so it doesn't interfere.
Can you send me your preset? With some standard presets I see no difference at all between version 7.42, 7.44 and the latest beta.
