Post new topic  Reply to topic  [ 154 posts ]  Go to page Previous 1 2 3 4 5 616 Next
 Post subject: Re: Stereo Tool 7.41
PostPosted: Tue Mar 04, 2014 1:58 pm
Didn't have any problems before with 7.41. Also today it ran perfectly
Did a virus scan but no results though..
The Power of Sound
PostPosted: Tue Mar 04, 2014 4:04 pm
So this suddenly happened after a Windows reboot? And 7.41 ran ok before? Then for now I'm going to assume that this wasn't a ST 7.41 issue...
PostPosted: Tue Mar 04, 2014 5:03 pm
It happened just after starting windows (no reboot) problem 1 occured. than problem 2.
Then I decided to reboot the computer and I had problem 2 again.
Reinstalled everything (because I'm impatient) and it's working fine again.
So still not sure if it was my system or ST, but because it was the first time that St froze I thought let's mention it here
The Power of Sound
PostPosted: Tue Mar 04, 2014 5:17 pm
I think this is not ST issue in this case
PostPosted: Tue Mar 04, 2014 6:19 pm
near05: This is only with the latest version? And does it crash when you close it, or during processing, or something else?
I think this occurs only while processing. the last time i changed something on the user interface i think and then the whole program crashes. i didn't remember what i did exactly, because it occurs very fast.
Here are some error details. The error occurs two times.
Quelle
Adobe Audition CC
Zusammenfassung
Nicht mehr funktionsfähig
Beschreibung
Pfad der fehlerhaften Anwendung: C:\Program Files\Adobe\Adobe Audition CC\Adobe Audition CC.exe
Problemsignatur
Problemereignisame: APPCRASH
Anwendungsname: Adobe Audition CC.exe
Anwendungsversion: 6.0.0.732
Anwendungszeitstempel: 518ade79
Fehlermodulname: vst_stereo_tool_64.dll
Fehlermodulversion: 0.0.0.0
Fehlermodulzeitstempel: 530e9808
Ausnahmecode: c0000005
Ausnahmeoffset: 00000000001bbeb5
Betriebsystemversion: 6.3.9600.2.0.0.256.48
Gebietsschema-ID: 1031
Zusatzinformation 1: ea39
Zusatzinformation 2: ea39ebb9842f67613ccdd06125187b86
Zusatzinformation 3: 5e37
Zusatzinformation 4: 5e37a69378e949e16fdaaad613061eda
Weitere Informationen über das Problem
Bucket-ID: fb02d66536032993ef9b5680c47d77d8 (85910551933)
Quelle
Adobe Audition CC
Zusammenfassung
Beschreibung
Problemsignatur
Zusatzinformation 1: 500c
Zusatzinformation 2: 500c32c39a5b9808cd523aff1182d45f
Zusatzinformation 3: b90b
Zusatzinformation 4: b90b46a5b93434ea909b3fa37848327f
PostPosted: Tue Mar 04, 2014 6:49 pm
Here i am again.
Under "About" it says that i have Version 7.40 (December 2013).
Just started ST and no problems at all.
So this version is older then the latest version?
Edit: Installed 7.41 and the first change i see is that my Non-ASIO output has an all blue bar.
With version 7.40 this bar was constantly moving.
I am running 7.41 now with Non-ASIO and ASIO Outputs at the same time.
Non-ASIO buffer = 0.070
ASIO buffer = 0.050
Soundcard = ESI Juli@
No problems at all and the CPU runs between 16 - 22 %, but mostly 16%.
Anyway, if I ever have an BSOD again, i'll post it here.
PostPosted: Tue Mar 04, 2014 11:06 pm
Here i am again.
ASIO buffer = 0.050
There was a bug in some of the beta versions that could cause crashes. Should still never cause a BSOD though. I'll await your results...
PostPosted: Thu Mar 06, 2014 12:23 pm
Hello All,
I had also the problem stereotool crashed all the time. What I did is remove all the register (regedit) edits and then installed stereotool again.
This solved my problem.
Maybe it could help you?
PostPosted: Thu Mar 06, 2014 1:44 pm
Hello All,
Which regedit settings? Stereo Tool should only put the install directory there for the uninstaller, nothing else!
And with which version was this?
PostPosted: Thu Mar 06, 2014 2:42 pm
I use standalone version 7.41 (64 bit Windows), only with ASIO FM MPX out and see no problems. I guess you don't use the standalone version? I think Hans will be happy when you have problems to be more specified which version you talk about (Standalone, Winamp, VST). When I see these problems, I can imagine that some people could be afraid to install Stereo Tool at all. Lucky I am not afraid for beta testing and always be prepared to go back to the version I successfully used before :)
