Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sat Mar 27, 2010 1:54 am
This should be the last update, until there may be a new version of Stereo Tool introducing new features.
That should be within a few weeks... :shock:
PostPosted: Mon Mar 29, 2010 5:47 am
Nice!
You should really hear the difference this preset makes with this CODEC - it takes just enough high frequency edge off. It also works great as an AGC (my whole goal of processing has always been to maintain source timbre as well as I can).
I look forward to the new version!
PostPosted: Mon Mar 29, 2010 12:09 pm
Biggest difference for you (I think) will be that the next version contains an RMS-based AGC instead of the current pre limiter. Besides that, there are mainly quality improvements, the CPU load is a lot lower (half of that of v4.22) and the latency is very low (100 ms at max quality, vs. upto 1.5 seconds in v4.22).
PostPosted: Wed Mar 31, 2010 5:39 am
The RMS-based AGC should be perfect.
Sounds like you've been busy! :)
PostPosted: Fri Apr 09, 2010 1:58 am
Updated taking advantage of AGC:
[Common]
Pre amplifier=10
Post amplifier=0.849999964
Extra loudness=1
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.224999905
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=1
[Noise Gate]
Enabled=1
Difference=0
Noise level=4.599999905
Relative noise gate level - Band 4=1.352941036
Relative noise gate level - Band 5=1.352941036
Relative noise gate level - Band 6=1.409638405
Relative noise gate level - Band 7=1.777777672
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=3
Attack speed=0.000001493
Decay speed=0.002917327
Above Top Limiter=0.370000005
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Remove remaining loud peaks=1
Maximum volume - Band 1=30000
Attack speed - Band 1=0.00000649
Decay speed - Band 1=0.000139355
Dual band=1
Relative expected volume of highs=0.200000003
Remove remaining peaks above (relative to maximum volume)=1.25
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=10000
Maximum volume - Band 0=10000
Maximum volume - Band 1=10000
Maximum volume - Band 2=10000
Maximum volume - Band 3=10000
Maximum volume - Band 4=10000
Maximum volume - Band 5=10000
Maximum volume - Band 6=10000
Maximum volume - Band 7=10000
Maximum volume - Band 8=10000
Attack speeds linked=0
Attack speed - Band -1=0.999998987
Attack speed - Band 0=0.999998987
Attack speed - Band 1=0.999998987
Attack speed - Band 2=0.999998987
Attack speed - Band 3=0.999998987
Attack speed - Band 4=0.999998987
Attack speed - Band 5=0.000034489
Attack speed - Band 6=0.000008546
Attack speed - Band 7=0.000008546
Attack speed - Band 8=0.000008546
Decay speeds linked=0
Decay speed - Band -1=0.999000013
Decay speed - Band 0=0.999000013
Decay speed - Band 1=0.999000013
Decay speed - Band 2=0.999000013
Decay speed - Band 3=0.999000013
Decay speed - Band 4=0.999000013
Decay speed - Band 5=0.000063811
Decay speed - Band 6=0.00010359
Decay speed - Band 7=0.00010359
Decay speed - Band 8=0.00010359
Above Top Limiter=0.680000007
Clipping enabled=1
Postprocessing enabled=1
Relative clip position - Band -1=-1
Relative clip position - Band 0=-1
Relative clip position - Band 1=-1
Relative clip position - Band 2=-1
Relative clip position - Band 3=-1
Relative clip position - Band 4=-1
Relative clip position - Band 5=1.222222328
Relative clip position - Band 6=1.150537491
Relative clip position - Band 7=0.801801801
Relative clip position - Band 8=1.150537491
Final limiter value=1
Final limiter decay speed=0.999000013
Final limiter clipping=20
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=1
Stereo Image Enabled=0
Stereo Boost Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=10
AZIMUTH change speed=0.109999999
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=15
Stereo Boost maximum amplification=0.699999988
Stereo Boost multiplier=0.899999976
Stereo Boost - Never reduce below original level=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=25
[Bass Boost]
Enabled=0
Strength=1
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=1
Start frequency=3500
Start speed=1350
Number of rotations=6
Smoothness=0.985999942
[Final Limiter]
Enabled=0
Difference=0
Pre-amp=0.5
Pre-limiter enabled=0
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title%        "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - www.stereotool.com/30s:\W"%artist% - %title% - %album%"
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=1
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Device ID=
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
AGC1.zip [2.18 KiB]
Downloaded 530 times
PostPosted: Sun Apr 11, 2010 6:48 am
Here's an update using swifter and smoother AGC settings.
[Common]
Pre amplifier=10
Extra loudness=1
Extra loudness - Deep bass protection - Enabled=0
Hard limit output=1
[Noise Gate]
Enabled=1
Difference=0
Enabled=1
Difference=0
Maximum volume=3
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=22500
Dual band=1
Enabled=1
Difference=0
Delay enabled=0
Clipping enabled=1
Relative clip position - Band 5=1.105262995
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=10
Extra phase shift=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Highpass filter=25
[Bass Boost]
Enabled=0
Strength=1
Clip level=1.5
Difference=0
[Phase Rotator]
Enabled=1
Start speed=1350
[Final Limiter]
Enabled=0
Difference=0
Pre-amp=0.5
Pre-limiter enabled=1
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=1
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
AGC2.zip [2.19 KiB]
Downloaded 593 times
PostPosted: Fri May 21, 2010 5:41 am
Wow, yes, I'm the same Aegrotatio from XMFan. Sorry I haven't replied in so long. I got excited now that 5.00 is out and visited and found all these messages I missed. I'm glad people who like deep, loud, kicking, processed sound are here with me!!
I love your presets!! Thanks so much. My interests are at the receiving end (after codec, not before it). My current music source is rather similar to XM (not Sirius). I use Digitally Imported, DI.FM, and I listen to their AACplus streams. They're only for paying subscribers. They have a sweet 64 kbps stream using AACplus with SBR, which sounds just awesome at such an extremely low bit rate, too. I'm always looking for an extra punch and your settings are awesome, too.
Again, thanks for your great presets!!
PostPosted: Wed Jun 09, 2010 4:20 am
This one is for Stereo Tool 5.10
[Common]
Pre amplifier=5
Post amplifier=0.949999988
Extra loudness=1
Extra loudness - Punchy=0.284999967
Hard limit output=1
[Noise Gate]
Enabled=1
Difference=0
Noise level=1.839999914
Relative noise gate level - Band 4=1.105262995
Relative noise gate level - Band 5=1.150537491
Relative noise gate level - Band 6=1.352941036
Relative noise gate level - Band 7=1.150537491
Enabled=1
Difference=0
Maximum volume=2
Attack speed=0.00000137
Decay speed=0.000763275
Above Top Limiter=0.5
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=18410
Attack speed - Band 1=0.000006174
Attack speed - Band 3=0.000006174
Decay speed - Band 1=0.000089597
Decay speed - Band 3=0.000089597
Dual band=1
Third band=1
Relative expected volume of highs=0.25
Relative maximum volume of highs=1.149999976
Relative maximum volume of very highs=0.199999988
Remove remaining peaks above (relative to maximum volume)=5
Maximum expected dynamics strength for smoothing=1.25
Enable smoothing=1
Smoothing time=30
Gating level=87025
Use ITU-BS.1770=0
Channel separation=0.75
AGC#2 Enabled=1
AGC#2 Maximum volume - Band 1=1.370000005
AGC#2 Attack speed - Band 1=0.000018678
AGC#2 Attack speed - Band 3=0.000018678
AGC#2 Decay speed - Band 1=0.000043198
AGC#2 Decay speed - Band 3=0.000043198
AGC#2 Dual band=1
AGC#2 Third band=1
AGC#2 Remove remaining peaks above (relative to maximum volume)=5
AGC#2 Gating level=87025
AGC#2 Channel separation=0.75
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 4=8809.999023438
Maximum volume - Band 5=5750
Maximum volume - Band 6=4750
Maximum volume - Band 7=4250
Maximum volume - Band 8=3899.999755859
Attack speeds linked=1
Attack speed - Band -1=0.000004539
Attack speed - Band 0=0.000004539
Attack speed - Band 1=0.000004539
Attack speed - Band 2=0.000004539
Attack speed - Band 3=0.000004539
Attack speed - Band 4=0.000004539
Attack speed - Band 5=0.000004539
Attack speed - Band 6=0.000004539
Attack speed - Band 7=0.000004539
Attack speed - Band 8=0.000004539
Decay speeds linked=1
Decay speed - Band -1=0.000017656
Decay speed - Band 0=0.000017656
Decay speed - Band 1=0.000017656
Decay speed - Band 2=0.000017656
Decay speed - Band 3=0.000017656
Decay speed - Band 4=0.000017656
Decay speed - Band 5=0.000017656
Decay speed - Band 6=0.000017656
Decay speed - Band 7=0.000017656
Decay speed - Band 8=0.000017656
Above Top Limiter=0.75
Clipping enabled=1
Relative clip position - Band 5=0.550387621
Relative clip position - Band 6=0.550387621
Relative clip position - Band 7=0.550387621
Relative clip position - Band 8=0.600000024
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=14.999999046
AZIMUTH change speed=0.209999993
Extra phase shift=0
Stereo Boost strength=7.5
Stereo Boost maximum amplification=0.75
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Highpass filter=25
[Bass Boost]
Enabled=0
Strength=1
Clip level=1.5
Difference=0
[Phase Rotator]
Enabled=0
Start speed=1350
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=1
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Volume=1
2AG9.zip [2.35 KiB]
Downloaded 580 times
PostPosted: Sat Jun 12, 2010 8:34 pm
This should be the last preset for 5.10 BETA. I find these results to be very satisfactory.
[Common]
Pre amplifier=5
Extra loudness=1
Hard limit output=1
[Noise Gate]
Enabled=1
Difference=0
Noise level=3
Enabled=1
Difference=0
Maximum volume=2
Attack speed=0.00000098
[Pre Compressor]
Enabled=1
Dual band=1
Third band=1
Enable smoothing=1
Smoothing time=30
Gating level=87025
Use ITU-BS.1770=0
AGC#2 Enabled=1
AGC#2 Dual band=1
AGC#2 Third band=1
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 7=4000
Decay speed - Band -1=0.000043198
Decay speed - Band 0=0.000043198
Decay speed - Band 2=0.000043198
Decay speed - Band 4=0.000043198
Decay speed - Band 5=0.000043198
Decay speed - Band 6=0.000043198
Decay speed - Band 7=0.000043198
Decay speed - Band 8=0.000043198
Clipping enabled=1
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
Extra phase shift=0
Stereo Boost strength=10
Stereo Boost maximum amplification=0.799999952
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Highpass filter=25
[Bass Boost]
Enabled=0
Strength=1
Clip level=1.5
Difference=0
[Phase Rotator]
Enabled=0
Start speed=1350
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=1
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Volume=1
2AG11.zip [2.35 KiB]
Downloaded 570 times
PostPosted: Sun Sep 05, 2010 5:52 am
Here's a more competitive version. If you want to update Stereo Tool with this one, Hanz, feel free.
Or, feel free to rename the prior one SuperH's Bit-Reduced MP3/AAC+ Optimizer (Smooth), and this one to SuperH's Bit-Reduced MP3/AAC+ Optimizer (Competitive).
Or, replace the old one altogether with this one. It's your call, of course, since it's your DSP application. :lol:
Based on what I know about the high frequency portion of the CODEC, I've devised this way to assist the high frequency content. It's working well.
Thanks and enjoy!
[Common]
Pre amplifier=7.5
Extra loudness=1
Hard limit output=1
[Noise Gate]
Enabled=1
Difference=0
Noise level=3.059999943
Relative noise gate level - Band 1=10
Relative noise gate level - Band 3=1.500000238
Relative noise gate level - Band 4=1.702702761
Relative noise gate level - Band 5=1.857142687
Relative noise gate level - Band 6=1.857142687
Relative noise gate level - Band 7=1.409638405
Enabled=1
Difference=0
Maximum volume=4
Attack speed=0.000001098
Decay speed=0.002424464
Above Top Limiter=0.629999995
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=15380
Attack speed - Band 1=0.000013767
Attack speed - Band 3=0.000013767
Decay speed - Band 1=0.000039987
Decay speed - Band 3=0.000039987
Dual band=1
Third band=1
Relative maximum volume of highs=1.25
Relative maximum volume of very highs=0.25
Enable smoothing=0
Smoothing time=0
Gating level=7920.999023438
Use ITU-BS.1770=0
Channel separation=1
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=7800
Maximum volume - Band 0=8000
Maximum volume - Band 1=8000
Maximum volume - Band 2=8000
Maximum volume - Band 3=6750
Maximum volume - Band 4=3900
Maximum volume - Band 6=5250
Maximum volume - Band 7=2500
Maximum volume - Band 8=3900
Attack speed - Band -1=0.000075273
Attack speed - Band 0=0.000075273
Attack speed - Band 1=0.000075273
Attack speed - Band 2=0.000075273
Attack speed - Band 3=0.000075273
Attack speed - Band 4=0.000075273
Attack speed - Band 5=0.000075273
Attack speed - Band 6=0.000075273
Attack speed - Band 7=0.000075273
Attack speed - Band 8=0.000075273
Decay speed - Band -1=0.000314613
Decay speed - Band 0=0.000314613
Decay speed - Band 1=0.000314613
Decay speed - Band 2=0.000314613
Decay speed - Band 3=0.000314613
Decay speed - Band 4=0.000314613
Decay speed - Band 5=0.000314613
Decay speed - Band 6=0.000314613
Decay speed - Band 7=0.000314613
Decay speed - Band 8=0.000314613
Above Top Limiter=0.610000014
Clipping enabled=1
Relative clip position - Band 3=1.150537729
Relative clip position - Band 4=0.550387621
Relative clip position - Band 5=0.754385948
Relative clip position - Band 7=0.307189584
Relative clip position - Band 8=0.550387621
Equalizer enabled=1
Equalizer position - Band 3=1.150537729
Equalizer position - Band 4=1.666666746
Equalizer position - Band 5=1.352941036
Equalizer position - Band 6=1.500000238
Equalizer position - Band 7=1.702702761
Equalizer position - Band 8=1.352941036
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=35
AZIMUTH change speed=0.150000006
Image phase amplifier=1.25
Image phase amplifier maximum angle=150.300003052
Image phase amplifier maximum separation strength=75
Image width amplifier=0.699999988
Extra phase shift=0
Mono or stereo only=-0.100000024
Stereo Boost strength=5
Stereo Boost maximum amplification=5
Stereo Boost multiplier=0.5
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Highpass filter=25
Highpass filter linearity=No
[Bass Boost]
Enabled=0
Strength=1
Clip level=1.5
Difference=0
[Phase Rotator]
Enabled=1
Start speed=3500
Number of rotations=2
Smoothness=0.975999951
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=1
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Volume=1
File comment: More Competitive - SuperH Version: 3AG8.
3AG8.zip [2.34 KiB]
Downloaded 564 times
