For ASIO mode: And the latest release (7.23) works fine with the same settings? If so, could you send me your settings file?
For non-ASIO mode: Does it work correctly with version 7.23?
I have tested the non-ASIO version on several systems, on one I get red bars as well - but that's also the case with the previous release (basically I cannot open both input and output, but I can open one of the two).
ASIO works fine here - are you using FM output with a sample rate below 176400? Because then it will act weird. (But I think it always has - will check that to make sure)
The machine I used is in service at the moment so can't check right now...
I think I installed the beta over 7.22 (SA). ST is running 192 kHz, card is a Trace 8.
At the time I was testing with a pipeline input and ASIO / non ASIO output on the Trace 8.
ASIO buffer looked like it wouldn't stay full. (Maybe as you suggest, it was CPU related?)
When trying the non ASIO output I got a message saying something like, "can't output at 192 kHz" or similar.
