Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 1 2 3 4 5 676 Next
PostPosted: Sun Aug 19, 2012 3:55 am
New version, with - as far as I know - all the browser issues fixed.
http://www.stereotool.com/download/ster ... 33-004.exe
It should look like this: (Tested with FireFox 3, FireFox 14, IE 9, Chrome 21).
PostPosted: Sun Aug 19, 2012 12:23 pm
I can slide a very long end to the right, can that be fixed?
Improved look of other panels:
PostPosted: Sun Aug 19, 2012 12:26 pm
O, I see what you mean... Will check it.
PostPosted: Sun Aug 19, 2012 12:28 pm
This is with the scrollbar. I'm using Firefox 14.0.1
PostPosted: Mon Aug 20, 2012 3:18 am
Ah, some slider values are way too high (or actually, the range isn't set correctly), which causes the handle to be displayed extremely far to the right. Once that's fixed the scrollbar at the bottom is completely gone.
PostPosted: Mon Aug 20, 2012 5:07 am
Some rendering errors in Opera 12.01 x64, but the overall look of the web interface is very nice.
PostPosted: Tue Aug 21, 2012 12:54 am
- Replaced slider by something that takes less space and looks better
- Slider range and curve for all the sliders is now identical to the normal GUI
- Added very precise control: Right-click on the left or right of a slider to increase or decrease the value by 1 unit (I will probably add some hold-behavior soon)
- Horizontal scrollbar is gone (unless you load very bad settings)
- Tested in IE, FF, Chrome and my phone (on my phone, dragging the slider does not work - clicking on it does).
http://www.stereotool.com/download/ster ... 33-005.exe
PostPosted: Tue Aug 21, 2012 4:49 am
I loved the last interface, congratulations on your great work :)
PostPosted: Tue Aug 21, 2012 10:53 am
Any chance to have the inputs and outputs for soundcards to be selectable?
