Post new topic  Reply to topic  [ 112 posts ]  Go to page Previous 1 2 3 4 5 612 Next
PostPosted: Thu Oct 17, 2024 6:36 am
Hi Hanz,
do you have more info about the config with .rist ? because as we have many disconnection i'm interested but don't find documentation about configuration with rist.
Thanks
Maybe it will help https://code.videolan.org/rist/librist/ ... umentation
PostPosted: Thu Oct 17, 2024 9:26 am
Hi Hanz,
Thanks
Try BETA022 that I just posted. You don't need to create .rist anymore, you can now enable RIST from the GUI. It needs to be enabled or disabled on both sides; if one side has it enabled and the other disabled you won't see any data.
(By the way, the only thing you had to do before was create an empty .rist file, but that's no longer needed now).
PostPosted: Thu Oct 17, 2024 9:39 am
Thanks for the clarification Hanz
PostPosted: Thu Oct 17, 2024 12:50 pm
Just curious for the TOVERLAND item. Are you having a company uitje? :P
PostPosted: Fri Oct 18, 2024 2:03 am
I am running 10.42 in a test environment.
I have UECP turned on and an RDS program talking to it. The Radio Text works fine using RT1 or RT=
However nothing I do shows DPS, I have tried DYNPS, DPS, & PS (all with and without a 1 on it.
Any idea what I might be doing wrong? Is there more that I need to prefix a DPS command with?
This may not be new to this version, but it is the only one I have actively tried to check this feature with.
Anyone with thoughts, please let me know.
Thanks everyone.
PostPosted: Fri Oct 18, 2024 7:28 pm
Mwahaha yes! I should probably remove that from the list, just had to make sure to finish a few things before I drive to Switzerland (I'm giving a presentation at the RDS Forum meeting).
PostPosted: Fri Oct 18, 2024 7:31 pm
Thanks everyone.
That should have worked! Is is specifically the "dynamic" part that's not working or does nothing happen at all?
For PS (static text):
PS
For dynamic PS (test should be split into parts):
DPS, PS_TEXT, DYNPS, DPS1
DPSTEXT
With this you can send anything using the formatting that Stereo Tool uses internally:
THIMEOPS
And for long PS:
LPS, LONGPS
PostPosted: Fri Oct 18, 2024 7:32 pm
BETA023 is posted. RIST code should be less buggy; top bar has been rearranged a bit.
PostPosted: Sat Oct 19, 2024 8:03 pm
Stt windows version don't work with mpx encoder with rist enabled
PostPosted: Tue Oct 22, 2024 10:32 am
Am running ST-64B-Standalone and MPX decoder on the Thimeo PI-4 image (BETA-023) and getting the same thing... :cry:
Turn RIST on and nothing. Turn it off in ST and MPX decoder and audio returns. Have tried client and decoder restarts.
Ross
