Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3 4 5 Next
 Post subject: Re: Stereo Tool 10.41
PostPosted: Tue Nov 19, 2024 10:13 am
So far any test I have done is showing the correct sample rate in Stereo Tool's VST plugin. Tested 32 bit VST on Windows, with and without enabling "Real I/O". So I don't know what can be causing this.
I've raised this issue also to the manufactor, but I don't know how fast they are able to fix it. Is there anyway to override the Samplingrate with an INI-Switch, to say, ok faulty it is announced 44100 but Stereo Tool, go 48000 anyway?
Thanks,
Christian
I don't know if it's their fault, in fact if earlier ST versions work normally it must be something on our end. I just don't know what that something can be. If anyone encounters another program (which is easier to install) where the wrong sample rate is reported, please let us know.
PostPosted: Mon Nov 25, 2024 1:42 pm
Just a guess: Could it be, that in older versions the default samplingrate of the VST Plugin was 48000Hz, so it was just a co-incidence that it worked?
PostPosted: Mon Nov 25, 2024 2:00 pm
What I understood from what you wrote is that the *only* change that you made was switching over to the newer ST build. If so, the sample rate should not have changed. If you did run it at 48 kHz before, then that would indeed explain why it worked back then.
PostPosted: Mon Nov 25, 2024 3:42 pm
Correct, I did not change anything else then replacing the DLL. But I meant, perhaps Stereo Tool had a different "Default Sample Rate" if nothing is communicated towards the VST from the Host. And maybe this assumption what is the samplerate was 48000 instead of 44100 in your code.
PostPosted: Mon Nov 25, 2024 8:05 pm
Ah. Every single VST call contains the sample rate, so that can't really be it.
PostPosted: Thu Dec 19, 2024 10:07 pm
Good evening,
I offer you my two French translations in the section:
https://forums.stereotool.com/viewtopic ... 23&t=27857
Enjoy :D
PostPosted: Sat Dec 21, 2024 12:42 pm
Hello Hans,
I've noticed that when I switch from English to French, the graphics processor goes into overdrive (from 10% to about 90%). What effect might this have on the software? Is this a bug?
PostPosted: Sun Dec 22, 2024 6:33 pm
Hello Hans,
Hi, just to clarify, are you talking about the GUI cpu thread as shown on the Resource Usage page? Or do you mean the GPU hardware itself is being used an especially high amount as seen in the Task Manager?
If the latter, what GPU is this? What OS, etc?
PostPosted: Sun Dec 22, 2024 8:56 pm
Good evening, Mr. Klorox.
Yes, I forgot to mention that this is the “User Resources” page. Once you've selected the French language in the software's “Language” menu, you'll see a percentage of excessive consumption on the top left. This is the issue I wish to address concerning the stability and fluidity of the rest of the application.
PostPosted: Sun Dec 22, 2024 11:44 pm
I see. This isn't happening here. I can't help but wonder if it's a CPU configuration issue.
Does it still happen if you assign the GUI thread to another CPU thread (preferably one unused elsewhere in the app)? What about changing the priority or the number of threads it uses in general via the Processing thread distribution selector?
