Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3 4
PostPosted: Mon Oct 07, 2024 8:35 pm
Hi.Just after a while i finalized this version.Some adjustments been made in various section
but i believe these are the best settings i could get from this preset. I will upload 2 versions
the "modest" with less agressive dynamics and the "hard" one for more dense and squashed
character. I hope you enjoy. Always good to have your comments and feedback :)
Duman - Dumans_HD_2.8_Adaptive_-6LUFS_-0.2dBTP_hard.zip [109.67 KiB]
Downloaded 374 times
Duman - Dumans_HD_2.8_Adaptive_-6LUFS_-0.2dBTP_modest.zip [109.77 KiB]
Downloaded 437 times
PostPosted: Sun Oct 27, 2024 12:20 pm
Hello Duman. For the past few days I've been testing the milder version of the preset and I don't have any examples. All the songs sounded awesome. I have now activated this preset with aggressive processing to see how it behaves. On some earlier versions of presets that had aggressive processing, it was possible to have a song that didn't sound good. If I come across a song that doesn't sound good, can I send you a link to the file of that song via a private message so that piracy doesn't spread through the forum?
PostPosted: Mon Oct 28, 2024 5:47 am
Hi.Thanks for the feedback. Its ok you can send me via pm something you notice that doesn't sound good just send me the original file as well in order to analyse what's going wrong with it. As far the aggressive preset i have noticed there are more things to tweak and add more pressure.
PostPosted: Wed Jan 08, 2025 8:02 am
Hi. After long testing i am posting a new one.
There are many changes made from the 2.8 version starting
from disabling auto EQ and natural dynamics and adding low and high
frequency extra processing (true bass, highs exciter) however the best
setting imho is mb compressor and the extra pressure it can handle.
Let me know your feedback and recommendations on this one.
Dumans_HD_2.9_Adaptive_-6LUFS_-0.2dBTP_pressure.zip [110.48 KiB]
Downloaded 318 times
PostPosted: Sat Jan 11, 2025 1:27 pm
This new version is not good for rock music. Sounds too rustling. I have returned to the 2.8 modest version.
