Post new topic  Reply to topic  [ 156 posts ]  Go to page Previous 1 2 3 4 5 616 Next
PostPosted: Thu Feb 08, 2024 4:33 pm
Sliders height still not fixed.
PostPosted: Thu Feb 08, 2024 6:27 pm
Hans, I don't get FM output with version 008.
fyi: I'm using VST in VirtualDJ.
What does that mean exactly? Are the settings missing? Do you get an error message? I assume that you're trying to send audio to the FM sound card from inside the VST? And did it work before?
PostPosted: Thu Feb 08, 2024 8:13 pm
[*]Increased 'Dense audio level boost' by 1 dB, this makes (based on test) very loud choruses about 0.5-0.8 dB louder.
please where can I find 'Dense audio level boost'?
PostPosted: Fri Feb 09, 2024 7:18 am
Multiband Compressor 1, Band Controls, Adaptive, >, and it's called "Make Dense Audio Louder"
PostPosted: Fri Feb 09, 2024 2:46 pm
Thank you
PostPosted: Fri Feb 09, 2024 6:22 pm
Ah, got it. Yeah the VST3 UI seems to work fine! But the VST2 UI is alllll sorts of screwed up. it's like the size of a desktop icon or smaller in height and all colors are black. I'd get a screenshot, but it's too small to make out.
I would recommend the VST3 format above the VST2 any day; and with this specific issue in VirtualDJ, the choice is clear.
edit: Ah, apparently the VST3 is giving me the color-changing hues in this host. And this time it's all colors, not just purple. Not sure I've ever experienced this bug in the VST3 either... it's hard to remember. And as expected, loading a skin stops the color changing, unless a default purple is loaded.
Okay, wow. Now I cannot reproduce this with the VST3 plugin. New or old. VST3 now behaves like vst2 did (blackness with tiny fonts) and I don't know why.
PostPosted: Fri Feb 09, 2024 6:44 pm
I get this message after installing a clean ST BETA010
PostPosted: Fri Feb 09, 2024 7:32 pm
Confirmed here. 32 bit is fine, 64 debug is fine as well, 64 release crashes. I will re-test debug, if that still doesn't crash I'll increase the stack for this specific thread.
Edit: This is a weird one. Stack usage must for some reason be at least 3 times bigger in release mode than in debug mode in this specific thread.
PostPosted: Fri Feb 09, 2024 8:18 pm
Ok Hans. Additionally, when I change presets the sound goes crazy
PostPosted: Fri Feb 09, 2024 8:56 pm
The exception is in the processing code, so I'll believe that :)
I'm running tests now; if everything seems fine I'll run a new build.
Edit: Due to changes from today, some of the Windows, Mac and Linux builds are all broken, and all in different ways. So, no build tomorrow.
