Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3 4
PostPosted: Tue Oct 19, 2021 12:49 am
011 with VST fix is available now.
PostPosted: Tue Oct 19, 2021 6:35 pm
Confirmed! Everything works again, and the display indeed looks much better than ever before! Well done
PostPosted: Tue Oct 19, 2021 8:19 pm
Ah, that behavior has indeed changed, and that old setting isn't used anymore. Try adding this one:
Don't ask to close to tray=7
7? Don't you mean 1? I'll try 7, but that should be added automatically into StereoTool in my opinion since all other settings are.
[update] I tried 7 and it worked, guess there are a lot of options to that feature. If you can add it, can we have a way to save settings or at least change close behavior with the web interface?
PostPosted: Tue Oct 19, 2021 9:51 pm
I'm not sure what you mean by "added automatically into StereoTool" - the first time you close Stereo Tool the .ini file is written with all the settings (including this one - it probably didn't exist yet because you couldn't close Stereo Tool though - this is how it works with all new settings that are added).
We have a new web interface coming where you can change all the "don't ask again"-type settings on one page, including this one.
And yes, there are more options now.
PostPosted: Wed Oct 27, 2021 6:44 pm
By the way, this is next:
Works for the BIMP now, not yet for adding/backup, but that should be more or less the same.
Edit: Add/backup works now too. But LiveWire doesn't for some reason. More tomorrow...
PostPosted: Wed Oct 27, 2021 10:38 pm
O, is it just same sync as on input1?
PostPosted: Thu Oct 28, 2021 12:40 am
Similar settings, but it syncs separately. And you can configure it differently if you want. So, if the 2 input sound cards have different clocks, they will both sync to the main output, which is exactly what you would want.
PostPosted: Thu Oct 28, 2021 2:22 am
And streaming via vlc as a backup? Will that work too? Where do we put the link abouth the streaming? :)
Regards,
MrDonT
PostPosted: Thu Oct 28, 2021 1:20 pm
Ah, this reminds me of the 80's back when I used a TBC (Time Base Corrector) to improve video editing. Smart idea use for audio!
PostPosted: Thu Dec 23, 2021 2:05 pm
It has been quite a while since the last beta post, so I figured I should announce it here as well: 9.84 BETA012 is posted here: viewtopic.php?f=14&t=31304
