Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3 4
 Post subject: Re: Tweaking Equalizer
PostPosted: Thu Feb 17, 2011 12:59 pm
Hm, until now I didn't even know that it was necessary to 'trigger' it - I just updated the settings in the INI file (and that is loaded on startup, before any playback starts, and due to that no trigger is needed).
Will fix it.
PostPosted: Fri Feb 18, 2011 12:31 am
Maybe it was my misunderstanding, but as far as I remember when you introduced this hidden option you said that the center frequencies could be changed via an edited STS file.
Anyway (especially for the VST version and its limited short INI file) it would be better to be triggered automatically with loading another STS file (for the MB GUI it already works - until now as a false positive indicator).
Better would be WYSIWYG.
This would give the additional opportunity to compare different center frequencies (or different numbers of bands) by loading STS files.
PostPosted: Fri Feb 18, 2011 3:15 am
Just to say that for FM this trick with disabled last two bands is not working.
