Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3 4
 Post subject: Re: Stereo Tool 9.35
PostPosted: Wed Oct 16, 2019 10:11 am
Btw I'm currently checking my traffic and found that connections are made to 'msg.stereotool.com'. What's that for?
I guess it`s for when you have a new version, ST shows this in a message...
PostPosted: Wed Oct 16, 2019 1:56 pm
When will Stereo Tool 9.36 BETA 001 be available? 😀
There's a lot of work "in progress" (no huge ST changes but lots of other things), we are working on it but I don't know yet when we'll post something here.
Yes.
PostPosted: Wed Oct 16, 2019 2:55 pm
Full screen mode does not always work. If it did I would have turned it on, but I've asked multiple people to try it and I have received replies that it doesn't work at all... This whole issue is quite tricky.
I see. It does seem nuanced.
Well how about a line that can only be written into vst_stereo_tool.ini (and doesn't get saved to an sts unless exporting all settings) that forces Full Screen mode for those of us who need it, without potentially breaking it for VST hosts for which that setting is not compatible?
Or is all this a currently fruitless endeavor since the team is working on a new GUI that may not have this issue?
Looking forward to seeing what you guys have in the work pipeline. Thanks!
PostPosted: Wed Oct 16, 2019 3:37 pm
Yes.
Never had such a message in all the years, even when I skipped some releases and kept an older one. However a connection is made on every ST start, even when the last one was only seconds ago. Isn't that a bit often for an update check?
PostPosted: Sun Oct 20, 2019 5:37 pm
It has taken a while, because we were half-way done with a lot of things, but there's a new beta: viewtopic.php?f=14&t=27200&p=60856#p60856
PostPosted: Mon Nov 04, 2019 4:15 pm
I'm having issue's with an Marian Trace Pro.
When i start ST, i am getting an error that relates to my driver. ( latest version installed )
When i reinstall ST it will work again, until i restart ST...the error returns.
With BBP One it works flawlessly
Sorry, I seem to have missed a few posts in this (older) thread. This has to be a Marian driver issue. Are you running ST in ASIO mode? And BBP as well?
PostPosted: Fri Dec 13, 2019 12:40 pm
Yes, i am running them both in ASIO mode.
FYI - this only happens on a Windows 10 Machine, Windows 7 does not have this issue
So:
Win 10 + Marian Trace Pro + ST ASIO = Error
Win 10 + Marion Trace Pro + BBP ONE ASIO = OK
Win 7 + Marian Trace Pro + ST ASIO = OK
Win 7 + Marian Trace Pro + BBP ONE ASIO = OK
