Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3 4
PostPosted: Fri Jul 16, 2010 4:28 am
Yes ST is comatible with AMD. I must test new Phenoms II and Athlons II ...
PostPosted: Fri Jul 16, 2010 5:33 am
Works on my Phenom II like a charm. No issues yet. :)
PostPosted: Fri Jul 16, 2010 9:04 am
Please note: This ONLY affects Pentium 3's! That is, if you get a warning during installation that the non-SSE2 version is installed. Otherwise there is NO difference AT ALL!
PostPosted: Fri Jul 16, 2010 7:57 pm
Hi Hans, Did you ever test stereotool on a atom netbook with a N270?
Or maybe any other freak who has tested it?
PostPosted: Sat Jul 17, 2010 6:59 pm
I installed the winamp dsp version on my netbook with atom cpu ,n270 , and the cpu is at about 50% with low quality and the sound is good! :mrgreen:
but with breakaway audio enhancer my cpu is slow and more cool ,the sound is good too :mrgreen:
PostPosted: Sat Jul 17, 2010 10:24 pm
Thx for the info. Second hand Asus 1000H is on the way for 150€ :-)
PostPosted: Sun Jul 18, 2010 3:15 pm
I don't have - or have access to - an Atom netbook, so I cannot test it - have to rely on others here...
I did test the Pentium 3 version on a (very) old Pentium 3, and it didn't crash, but the CPU load was insanely high which made it completely unusable - with everything disabled, quality High and screen refresh rate High the CPU load was already around 80%. Reducing screeen refesh rate helped a lot to my surprise - I'll look into that, it could be that some unnecessary processing or screen updates are being done. With quality at its lowest and screen refresh rate to 0 (CPU load around 20-25%), just enabling Multiband also increased it to over 90%.
(Maybe some faster Pentium 3's could use the new version, but for mine it's completely useless).
By the way, I also did some quick tests on my old Pentium 4 (on which I created and tested all Stereo Tool versions upto 3.something), and it seemed that the CPU load is varying quite a lot. I could get it to run on the Pentium 4, with everything enabled, at a CPU load near 50%, which is quite good (in fact similar to the CPU load of the early 3.1x versions, but with FAR more processing enabled and at a higher quality than before).
Did anyone else experience wildly varying CPU loads when switching filters off and then back on?
PostPosted: Sun Jul 18, 2010 5:14 pm
The "VISIT SITE" button was being redrawn at every screen update. Fixed, upload coming soon. (Should not make a lot of difference, except on extremely slow pc's).
PostPosted: Sun Jul 18, 2010 7:26 pm
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... A502-D.exe
Stand alone version: http://www.stereotool.com/download/ster ... A502-D.exe
VST version: http://www.stereotool.com/download/vst_ ... A502-D.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... A502-D.dll
Command line version: http://www.stereotool.com/download/ster ... A502-D.exe
PostPosted: Sun Jul 18, 2010 8:32 pm
This seems to be all for now (cleaning up action), so I'm going to release this version now.
