Post new topic  Reply to topic  [ 78 posts ]  Go to page Previous 1 2 3 4 5 68 Next
PostPosted: Sun Feb 03, 2019 11:19 am
Hans, this beta (007), the preset is not correctly saving the AGC settings.
I've just tested it but I don't see any problems. Can you tell me exactly what you're doing and what doesn't get saved/loaded?
The stereotool does not save the *.sts correctly but the% USERPROFILE .ini file is saved correctly, or the settings remain in the program if you do not change the preset but if you save it and want to go back it is not possible because something is missing being thus, the preset was not saved.
No, I'm not seeing this.
What I tried:
1. Change a lot of AGC values
2. Save the AGC settings to "a.sts"
3. Hit RESET -> ALL
4. Load AGC settings from "a.sts"
I don't see anything weird. So, what are you doing? I also did this same test with saving ALL settings instead of AGC only, and that worked fine too.
PostPosted: Tue Feb 05, 2019 1:53 am
What I tried:
3. Hit RESET -> ALL
That's weird! I must have done something wrong, now it worked. Anything I report here again. Thank you Hans.
PostPosted: Tue Feb 05, 2019 5:15 pm
Is it possible to make a selection box for streaming output, just like normal output has? So I can decide to send the unprocessed signal, or the HD, or de-emphasised FM signal... Now it's only the HD output
PostPosted: Thu Feb 07, 2019 10:24 am
We are working on a whole new I/O section, and this will definitely be part of that. But it may take a while...
BETA009 is available! I think we're ready for a release build now :)
PostPosted: Thu Feb 07, 2019 10:41 am
With still wrong AGC meter when using window vs no-window?
PostPosted: Thu Feb 07, 2019 11:49 am
Ah. Good point. And confirmed now. Will check what's wrong with that.
Edit: Ok, that was easy. Fixed.
PostPosted: Thu Feb 07, 2019 5:11 pm
Hello,
Here is an idea for a future development : it will be to add multiband expanders on the multiband 1, with attack, release, threshold and ratio settings. I know a former French processor who had these expanders and the sound sounded very mellow.
The process I am talking about can be reproduced with the VST plugin "Wavearts multidynamics", with the preset "Basic Expander", but in multiband.
PostPosted: Fri Feb 08, 2019 1:43 am
BETA010 is available. But some of the builds unfortunately failed...
PostPosted: Fri Feb 08, 2019 3:28 am
Ok AGC meter is perfectly fine now. Now just "Gate after AGC" button and WB Compressor from Legacy AGC :)
