Post new topic  Reply to topic  [ 58 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Fri Jun 02, 2017 6:00 pm
The "covfefe" puts a right-leaning bias on your audio while removing unnecessary press noise. :D
J0HN II
PostPosted: Fri Jun 02, 2017 9:48 pm
I still have to figure out a name for it - this seemed to be a good place holder :)
PostPosted: Fri Jun 02, 2017 11:40 pm
latest beta sounds wonderful :D :D :D
PostPosted: Sat Jun 03, 2017 10:40 am
Windows stand alone: http://www.stereotool.com/download/ster ... 36-009.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 36-009.exe
VST: http://---.stereotool.com/download/vst_stereo_tool_BETA836-009.dll FAILED
VST: http://---.stereotool.com/download/vst_stereo_tool_64_BETA836-009.dll FAILED
- RDS word wrap chance for ArcticPalm: Split words if needed. Dave Hartman.
- Added Covfefe follower to greatly improve consistency in the new RMS mode for high Covfefe values
OLD CHANGES
- New RMS mode: Compensate for release speed difference. Is going slower now for bigger drop. New RMS mode: Release is slower for bigger distances, should I fix that? -> See new Covfefe slider (I still need to name it properly)
- SST upload / confirm / download / delete presets
- Long STS file names fixed (more)
- Sound card issue in Generic plugin (2 threads)
- Triple ,0 with GUI doesn't work WAITING FOR FEEDBACK
- New RMS mode: Add channel linking (Explanation will follow)!
- There is a settings bug. If you load any preset, the Leif composite strictness seems to go down to 8. I use 9 in my settings, but I have to reset it to 9 anytime I load a preset, even if that preset already uses 9. -> Long names in the STS file were cut off!
- Clipper "Prioritize loudness" mode. Now also works for non-composite clipper, and much bigger effect.
- LW version removed Diff, Hear, Absolute Highs
- AGC bug: Window did not work properly (caused clicking sounds and jumps) with AGC block sizes smaller than the default block size.
- Clipper: Prioritize Loudness works for composite clipper (see Advanced Clipper -> Sound). Might need further optimization.
- Bug fix (8.34): EQUALIZER could change to Phase Delay graph and vice versa.
- RMS same behavior for DC Waiting for feedback
- Bug fix (8.34): EQUALIZER was still not ok, should be now.
- New RMS mode split in 2 modes: "RMS" which has the same behavior as Peak and Old RMS for DC offsets (the standard behavior), and another new RMS mode with 1.8 dB higher thresholds to be nearly identical to the old RMS mode, to make it easier to convert presets to the new RMS mode.
- Test new RMS +0.9 mode levels, compare with old RMS. -> Was wrong, back to +1.75
- Test Covfefe pressure_follower with low frequency sine waves and fast release to make sure that it's roughly correct.
- Test Covfefe pressure_follower with different release times to make sure that it's correct.
- Fix "Not registered" message
- Fix anti-phase. Tested and seems to work, needs to be implemented to always work.
- Check if 'Prioritize loudness" works as planned, doesn't do too much
- Maybe suggest auto-update for presets?
- Fix some warnings.
- uMPX web interface
- Test clipping
- Classical music compressor
- NAB
PostPosted: Sat Jun 03, 2017 2:49 pm
Whereas beta 008 was *very* fun to listen to, beta 009 grew up, got a job, and settled down. Beta 008 was fun in high school, but beta 009 has money to spend.
You can take any current preset and just change the mode to the new RMS (white noise calibration), and you're finished. Good work, Hans. I can't imagine people will need to tweak their preset very much, if at all.
PostPosted: Sat Jun 03, 2017 5:54 pm
I agree the 009 sounds super professional. I'm using the DSP on Winamp and noticed in Extreme Tweaker mode @ SB clicking on the tab below "Side chain" causes an undesirable effect with the layout. This also occurs in 008 also, but not in 007 (it's fine there).
PostPosted: Mon Jun 05, 2017 7:00 pm
Windows stand alone: http://www.stereotool.com/download/ster ... 36-010.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 36-010.exe
VST: http://---.stereotool.com/download/vst_stereo_tool_BETA836-010.dll FAILED
VST: http://www.stereotool.com/download/vst_ ... 36-010.dll
OLD CHANGES
- WatchCat 374 error WAITING FOR FEEDBACK
- WatchCat continuous rename error [MATHIJS] WAITING FOR FEEDBACK
- Check if 'Prioritize loudness" works as planned, doesn't do too much -> Adjusted slightly, a bit more bass around 50-100 Hz (0.05 dB) has only a very small (0.02 dB) effect on mids.
- Removed build warnings - TEST PEQ still ok in web interface -> Ok
- Slightly optimized drawable eq display in web interface.
- Optimize new RMS?
- Test full build with fixed warnings
- ASI test
- Exception Jelle
- Smarter stereo-to-mono conversion (only when needed)
- Test clipping
- NAB
PostPosted: Tue Jun 06, 2017 3:05 am
Again a new step to better quality... but Hans, where will you stop... SUMMUM ?
PostPosted: Tue Jun 06, 2017 3:14 am
Hans, do you think you could recreate that kind of "phazing" i love so much in the lower bands ? just as Emmanuel-Dylan Petit succeded with it's audio processing Stack ? (it could be assorted by a slider that add less or more effect... or a total OFF button) I am sure you can do that, the same way you did for "phase delay"... for me that would be the greatest step to the most crazy audio processor i will never heard ! Please Please, i know you've the skills to do it...
i am speaking of that audio file : https://www.dropbox.com/s/pz7g8vu5a7zmd ... 9.wav?dl=0
PostPosted: Wed Jun 07, 2017 9:14 am
I think phase delay should be implemented in some other way because now it sounds too "noisy" espesially on sharp voices.
Urban Junglist
