Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 128 29 30 31 3235 Next
PostPosted: Mon Aug 03, 2015 12:01 am
Stereo Tool 7.71 BETA023
Windows stand alone: http://www.stereotool.com/download/ster ... 71-023.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-023.exe
Windows 32 bit VST: http://www.stereotool.com/download/vst_ ... 71-023.dll
(Repeated) Note: Big memory usage reduction (78 MB!). Might cause problems (although I haven't seen any yet).
- Fixed FM tilt correction GUI issue.
- Exception reported by DJ_DOGGY fixed.
- Make OldSamples buffers (and potentially others) dynamic to save memory - Currently allocating 85 MB just to display waveforms!!!
- Optimize memory usage: Don't allocate more than MAX_SAMPLES_ST for blocks which only get downsampled audio. So only allocate a few things bigger.
- Change tone generation FM enable/disable and order.
- VST multiple instances fails - Tested and works fine. Ignoring unless I'm receiving a better report. Note: 32 bit too many instances can crash due to the 2 GB limit. Max number is now 3, used to be 6 so some optimization could be useful.
- Make VST window bigger
- Fixed Quality slider bug introduced in previous beta
- Fixed jumping pilot and RDS effect on some 'Ignore frequencies above' frequencies.
- Sometimes the top and bottom waveforms run at different speeds when Ignore Frequencies Above is enabled.
- Make Chain block (small size) based - Partially done
- Declipper display is broken. Even without Ignore Frequencies Above. Ok upto 100 ms. Also broken in 7.70!!! Only if samplerate > 48 kHz, and when switching between sizes, upto 100 ms everything is fine (even if no audio is playing so no refresh of the data occurs), so the bug is in the displaying code. -> Was a shift error, fixed.
- Again, fixed noise level jumps and spike at Ignore Frequencies Above frequency.
- Clipper issues Leif / Wolf Stahl (probably the same thing) - Should be fixed now. - Waiting for reply Wolf- Check new clipper highs
- Remove "Take some shortcuts" under CPU, probably broken! And has not much effect anyway. -> Hm, no, must have been in use for the tests. Ugh... TEST to check what is better: ON (which will probably allow more sounds through) or OFF. -> Actually it does seem to work AND allow more highs through, but I don't know if that's a good thing - more tests needed!
- Added lowpass filter after clipper in non-composite mode.
- Fixed problem with click sounds (reported by DJ_DOGGY). Reduced output level by 1% - you can safely increase modulation by 1% if you're using an output that's affected by this (should only be FM signal inside a plugin). If you're using the stand alone version, make sure to set the output level to the sound card no higher than 99% (-0.1 dB).
- Fix downsampling and Quality slider problems: Lower Quality setting
- Attempt to reduce effect on volume of using Leif's clipping method.
- Fix DJ Doggy's reported errors (19 kHz, junk around tones).
- Ignore frequencies above a specific frequency -> Should lower TOTAL CPU load by another 10-20% (now fully implemented except at lower Quality settings)
- Fixed the lowpass bug that was introduced in 009. Although it has probably always been there! As a side effect, the output is also slightly louder (about 0.02 dB) with no negative effects.
- Fixed distortion introduced in 009/010. Extra highs are still there though! See new 'Sparkling highs' section under Advanced Clipper -> Sound
- Fix optimizations
- Fix code #warnings
- Some small optimizations
TO DO 7.71:
- Synchronization is broken in 008 (was ok in 007) - Don't see it! Is anyone still seeing this?
- Reduce memory usage further (check all MAX_SAMPLES_44K arrays including SS and multi_samples) - Effect is small (about 0.5 MB) - not worth the effort.
- Check all #pragma messages. Mostly done.
- Fix reported glitches/hiccups?
- Add delay (in samples) for one of the two MPX channels to send audio to allow synchronization of 2 transmitters which use the same frequency. (John Markis)
TO DO 7.72:
- Add impulse response import function!!!
- Noise learning Micha
- EQ with 'standard' sliders.
PostPosted: Mon Aug 03, 2015 11:04 am
Confirm the "tilt" exeption issue is FIXED.
Memory usage on this beta23 is around 126 000 Kb. With 4000 less than beta22.
PostPosted: Mon Aug 03, 2015 1:18 pm
I'm going to continue fixing other minor issues; if anyone gets any glitches please try to record them (if anything else fails, on your phone or something) so I have an idea what to look for. Also, if you can (if you're not on the air), please try disabling filters and features to find the cause.
PostPosted: Mon Aug 03, 2015 9:14 pm
Yea "input tilt" does not freeze gui in b23.
PostPosted: Tue Aug 04, 2015 4:18 am
Stereo Tool 7.71 BETA024
Windows stand alone: http://www.stereotool.com/download/ster ... 1-024A.exe FIXED
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-024.exe
Windows 32 bit VST: http://www.stereotool.com/download/vst_ ... 71-024.dll
- Optimized Stokkemask exciter code
- Optimized output to lower sample rate sound cards (includes plugin hosts). Overhead (CPU load even when all processing is disabled) is greatly reduced. Risky change.
- Tested a large number of other small things (there were a bunch of remarks that I placed throughout the code, and most of them are removed now).
- Fix optimizations
TO DO 7.71:
- Fix >48 kHz Normal Output issue in stand alone version.
- Fix Linux version (someone mentioned that it crashes after a few minutes, on Ubuntu 14.04 - re-check with Valgrind)
TO DO 7.72:
PostPosted: Tue Aug 04, 2015 7:21 am
Ok, so I left Beta 023 run overnight to see if the problem I experienced would start. When I checked, I heard serious clicking / garbling. I will try and upload a clip.
The glitching appeared to follow some movement in the output (ASIO) buffer (very small fluctuations up and down, but never got visually empty).
Disabling 'ignore high frequencies' cleared the bad glitching but the buffer still had small fluctuations up and down, now at a much higher frequency than before.
CPU load seems fine, even when looking at individual cores.
I wanted to know if changing the sample rate would make a difference so I changed from 192kHz to 176.4khz and the serious glitching problem apparently got 'reset'.
Hope that this helps a bit.
PostPosted: Tue Aug 04, 2015 7:37 am
You use ASIO . I knew it ..
Secondly i knew that is buffer related, because you said issue appears after "one night" or two.
May be Ignore freqs is not included in the Synchronize of ASIO (if exists) and after some time ..... something happens.
Why you use 192 Khz for input ? You already have max 48 Khz of input music ? What is the idea to resample the "garbage" . It stays garbage .
Changing the sample rate is "clear" the issue because program REFILLS the buffers. After another night , you will get the same . Try it !
I`ll wait for the clip to take a look.
And something from me : I don`t like ASIO . It can sounds crazy or funny..... but i don`t.
PostPosted: Tue Aug 04, 2015 1:35 pm
@2sense: I've browsed through your posts and listened to the recording that you made; it seems as if for some reason the number of samples sent to the output is lower than the number of samples that comes in. Except that I would expect that you would see it in the buffer filling, and according to your description that's not the case (or does it get less full over time?)
How big did you set your ASIO buffer?
PostPosted: Tue Aug 04, 2015 2:16 pm
@2sense: 2 more questions:
1. Does it also happen if you disable 'Ignore frequencies above'?
2. Can you send me your .ini file? Other people (except Cornyman) aren't complaining about this so I'm unsure what's happening - there may be something special in your settings that almost nobody else uses. I don't know what that something could be though.
PostPosted: Tue Aug 04, 2015 2:17 pm
I have just replaced the 024 stand alone beta (it was broken), please ues 024A.
