Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 128 29 30 31 3276 Next
PostPosted: Thu Mar 08, 2018 1:08 pm
-SNAP-
Ok so Symmetric Peak was actually routed incorrectly in the software. And FB^2 mode in Symmetric RMS wasn't perfect (it could get some overshoots on really extreme content). Both issues are fixed now, and I changed Symmetric Peak to now be based on Symmetric RMS instead of Symmetric AVG, which is still not good and will be removed after I'm done with testing.
Edit: Now fighting with a compiler bug (the compiler crashes during compiling...). If I manage to fix it before I fall asleep I'll post a new beta tomorrow morning. Otherwise it will take longer.
PostPosted: Fri Mar 09, 2018 10:08 am
Stereo Tool 8.55 BETA036
Windows stand alone: http://www.stereotool.com/download/ster ... 55-036.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-036.exe
VST: http://www.stereotool.com/download/vst_ ... 55-036.dll
- Fixed Symmetric Peak
OLDER CHANGES:
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Fix Basstardizer crash
- Check Auto EQ behavior on sudden level changes, and initial Auto EQ behavior after startup
- Optimize new compressor modes, create separate "NICE_MODE" code paths, put all values in a LUT.
- Test NanoPi
- Classical preset
- NAN seen when switching to new compressor mode which also doesn't get recovered - silence afterwards. (Peak mode recovers it though).
- New skin
- Is pre AGC affecting audio levels? (With BS412) -> Not specifically for BS412, but it slightly reduces the level even if set a lot higher. Probably needs some offset.
- Aanvraag uren
- AM streaming output
- Add AM presets
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
Important: The CPU load is really high right now. I will optimize it later.
Also important: You can't just enable this new mode and expect everything to be fine without changing the settings. For small level differences there won't be a difference, but there will be for big differences. You'll definitely notice the slower attack on big level jumps.
PostPosted: Fri Mar 09, 2018 1:35 pm
2 issues:
8.55 beta 036 / 035 : loaded 8.23 sts file and after that auto eq settings. Processing stopped, sometimes comes up after 20 seconds, but not always. When processing on tried to load earlier bass eq settings this now works but when I change effect strength the processing stops again, in fact any change in auto bass eq stops processing. This without crashing
Setup : ST 32 bit VST loaded in Foobar.
Cannot enlarge ST. The final limiter still not shows (also not in Wavosaur). This is a bit complex because loudness really needs to be controlled when auto eq's get on.
Info on this: Windows 10 , display size 1920X1200 or 1280x1024 (both don't enlarge)
HWinfo :
https://maasstad.online/
PostPosted: Fri Mar 09, 2018 1:46 pm
Hello Hans,
The Basstadizer module when activated causes the application to stop.
Name of the failed application StereoTool. exe, version: 0.0.0.0.0, timestamp: 0x5aa1fb4e
Default module name: StereoTool. exe, version: 0.0.0.0.0, timestamp: 0x5aaa1fb4e
Exception code: 0xc000000409
Error offset: 0x00000000000205b84b
Faulty process ID: 0x16e0
Start time of the failed application: 0x01d3b7a16cb3388f
Failed application access path: C: \Program Files\Stereo Tool\StereoTool. exe
Defective module path: C: C: \Program Files\Stereo Tool\StereoTool. exe
Report ID: 616c1207-147b-4c91-abe3-d0dd3627f98d
Full name of the faulty package:
PostPosted: Fri Mar 09, 2018 2:38 pm
Hello Hans,
I see that I forgot to turn off writing intermediate test data to file. If it can't open that file it crashes. This may also explain the other hanging behavior... I'll remove it and build a new beta tonight. For now, avoid Basstardizer :(
PostPosted: Fri Mar 09, 2018 2:52 pm
Ok Hans, your software is the ultimate in this field and affordable compared to dedicated devices, thank you for your investment and attractiveness of your work. :P
PostPosted: Fri Mar 09, 2018 3:18 pm
Yeah, I was just going to post that enabling the Basstadizer crashes VST Plugin Analyser. :P
PostPosted: Fri Mar 09, 2018 10:06 pm
The fixes for symmetric peak mode look good. It's pretty seamless to move from old peak to new peak. The main recommendation I would have for people is to slow all releases down by about 20% when moving from the old peak mode to the new one. In my opinion, that provides the best general approximation of the old mode, so you have a reasonable starting point.
PostPosted: Fri Mar 09, 2018 10:15 pm
That depends on used Attack. Erlier on old modes not.
PostPosted: Fri Mar 09, 2018 10:18 pm
Actually attack seems about spot on. I haven't measured, though. The new mode definitely releases faster for any move bigger than about a dB. That's why I suggest slowing those times down about 20%. No doubt, many of the moves will be larger than 1dB. :)
