Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 127 28 29 30 3159 Next
PostPosted: Tue Mar 22, 2016 9:58 pm
I got multiple questions about this, so to clarify:
The whole encryption stuff has nothing to do with normal licensing, there are people who want to be able to sell presets so some encryption is needed for presets. I'm not planning to change my license system! I *hate* subscription abbo's.
PostPosted: Tue Mar 22, 2016 10:33 pm
Wouldn't the settings still be visible in the ini-file?
PostPosted: Tue Mar 22, 2016 11:35 pm
The INI file would also need to be encoded if an encoded preset is loaded. Or at least part of it. That's one of the difficult parts of this (I'm not even sure if it's really possible yet).
PostPosted: Wed Mar 23, 2016 8:00 am
I know we may use ST for a special purpose which it may not be considered for, but we maintain a big bunch of presets for several years now. Changes are generally made programmatically (by writing to presets or ini-files) because it would be impractical to do them by hand.
So if you *always* encrypt presets and ini-files this would be the end of our work (unless you provide full programmatic access to ST, which would be the best way, anyhow).
Btw, why are presets settings copied over to the ini-file at all? It would be enough to just remember which preset to use and load all settings directly from it into ST (or maybe only doing so if a preset is encrypted?). This should also make things easier for you because one would only need to encrypt the presets one wants to and everything else could stay unencrypted.
PostPosted: Wed Mar 23, 2016 11:35 am
Dear hvz,
When do you think to have the software compliant with 384Khz sample rate?
Im using 67Khz and 92Khz SCA subcarriers in my system and the 92Khz subcarrier with the 192Khz sample rate gets very distorded.
Thanks.
Hm, not really looked into that at all yet. It's not a trivial change, and I don't think there are a lot of people using SCA2, who also have a 384 kHz capable sound card...
Dear hvz,
The SCA2 exists in your software, it is important that it is working well! There are many sound cards already 384kHz, just give a visit on ebay and with good prices.
This is mine and I inserted into the transmitter link: http://www.ebay.com/itm/SA9227-PCM5102A ... SwZ8ZW5hx5
This change is important to me, I'll wait ...
Thank you for your work in this fantastic software.
Regards
Filipe
PostPosted: Wed Mar 23, 2016 1:03 pm
Don't worry, that will keep working. (As long as you don't load an encrypted preset).
PostPosted: Wed Mar 23, 2016 1:38 pm
Hey, i m back !
And the reason is ..the encrypted presets ( i am planning to give some presets for FAT and HOT sound for FM and HD radiostations :)
Hans, the SCA channels work fine for me . ( realtek onboard soundcard on Intel I7 )
Indeed the upper SCA channel is a bit low presence ...but it s ok.
Thank you for your excellent software Hans !!!!
PostPosted: Wed Mar 23, 2016 2:12 pm
Hey, i m back !
It is true that the subcarrier 92Khz is present, you do not have 6 kHz wide band (you only have 2 or 3 kHz). Audio lower and has more noise. Lack spectrum, as shown in the attached photo. ;(
In subcarrier 67khz no problem.
With 384kHz this problem is solved, and improves other aspects of the sound. because the Sample Rate is double.
File comment: SCA file
PostPosted: Wed Mar 23, 2016 4:48 pm
7.85 BETA048
Windows stand alone: http://www.stereotool.com/download/ster ... 85-048.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-048.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-048.dll
CHANGED:
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Add MPX input support for analysis
7.85 but after NAB:
- Exciter: Add auto-adjust HPF frequency
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem?
LATER:
- O skin
PostPosted: Wed Mar 23, 2016 7:57 pm
The new version is so great! When you combine the hole filler with the absolute highs filter, it sounds result now total natural. this is in contrast to the last version really a significant difference. what was in the linked article online was actually correct. when all is rippling away, it sounds much more relaxed. good work!
