Post new topic  Reply to topic  [ 292 posts ]  Go to page Previous 126 27 28 29 30 Next
PostPosted: Sat Dec 21, 2013 1:47 am
Lower CPU usage indeed...very nice. Like the numerical db indicators. What is the additional single display on the right side of Levels?
FM MPX power.
And it would be nice to be some nicer (multi)color
PostPosted: Sat Dec 21, 2013 2:19 am
Spend some time on making a new help framework...
Yes!! Excellent. To keep your boredom at bay just keep thinking of how what you write will help a lot of us get a better understanding of the features available to us in ST and because of that take more control over our sound. I can't wait for some of those "oh, that's what that does" moments here.
Clipper
PostPosted: Sat Dec 21, 2013 8:25 pm
You've come a long way and the added product features have been fantastic. Congrats and I'm proud of you. ST takes on the big boy boxes and comes out a winner!!!
Richard, are you planning replacing BBP for ST soon ?
PostPosted: Sat Dec 21, 2013 8:50 pm
Not sure who Richard is, and yes i left BBP in the dust along time ago. ST rules!!
PostPosted: Sat Dec 21, 2013 9:17 pm
Ah, i thought you were the guy from the Netherlands who runs the local radio station in the north of the country.
Guess i am wrong....forgive me. :oops:
PostPosted: Mon Dec 23, 2013 6:53 pm
RELEASE CANDIDATE
Windows stand alone: http://www.stereotool.com/download/ster ... 32-031.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 32-031.exe
Windows VST: http://www.stereotool.com/download/vst_ ... 32-031.dll
Command line and Linux versions are also available but I don't have time now to look up the links...
Mac and 64 bit still needs to be built.
CHANGED IN THIS BETA:
- Updated some presets
OLD DONE:
- Moved Phase Shaping to under Phase Rotator (since it's hardly used or useful).
- Join input sound cards for Rockland/Radio SAW.
- Renamed some Natural Dynamics settings for clarity.
- Test new compressor performance --> HAS IMPROVED!
- Add DIFF mode for Power Bass
- Check low latency Power Bass mode -> Was broken, fixed
- Add presets DONE
- Fix compressor optimization (keep 2 new lines switched off if not needed)
- Check existing presets on RMS mode, settings must be updated. Check effect of new RMS compression/limiting. What to do with block sizes? Check old presets... Also check what to do with better limiter settings. Weird: Some presets are ok without any modifications, others are very different...
- Change version number
- Finish or remove Gas Mode. Release is probably good now, but I think I should not touch attack (at least for now) - so restore the old code. Not sure if this is thing is useful? --> Ok, attack mode fix make the attack mode sound much closer to the Gas attack mode. Renamed Gas mode back to Continuous Release. Should be good now.
- Updated existing presets with RMS mode compression (but maybe I can automate it)
- Auto-set RMS block sizes per band.
- Power Bass does not work too well with side chain with a lot of bass reduction New mode added (and also maximum effect added), waiting for feedback...
- Added Controlled Distortion, including intermodulation distortion detection
- Rewrote Stokkemask code and added some options to control behavior and CPU load. For a similar behavior as before (yet at a lower CPU load), use Audio Quality 0, no skip, no faster. Faster seems to have very little impact on the signal but reduces CPU load, Skip reduces it further but causes bigger overshoots, with far less impact on audio. A higher Audio Quality greatly reduces the impact on the audio (especially if you leave 'allow small overshoots' at 0).
- More than 2 channel audio compressor issue should be fixed.
- Use RDBS names when using 75 us pre-emphasis viewtopic.php?f=16&t=4869
- GUI closing warning viewtopic.php?f=16&t=4708
- Fix AGC problem (release doesn't respond the same at very high input levels). Old behavior still present for compatibility.
- AGC improvement: Bojcha reported that the AGC gives a much more consistent output at lower latency settings. Now, at higher latency settings you can replicate the lower latency settings behavior (See AGC -> Bands -> Block size; suggested value is 1024).
- Added AGC matrix mode (L+R/L-R processing)
- Added full screen mode (Configuration top panel), this hides all window bars and should also hide the Windows task manager. Especially useful for small (eg. 7") displays.
- Limiter improvement: Bojcha reported that the compressors (mainly the limiters) give a much more consistent output at lower latency settings. Now, at higher latency settings you can replicate the lower latency settings behavior (See the 'Block size' parameter (under 'detection'), available for all compressors (singleband and multiband per band). Very low settings can cause bass intermodulation distortion.
- Added multi-language support
- Command line version --samplerate option to use different sample rates. With this, it's now also possible to output an MPX signal (but the input sample rate needs to be high enough, since input and output sample rates are still identical).
- Command line version --r128 option for R128 normalization. Including options to set the target level (default is -23 LUFS) and max TruePeak level.
- Improved and optimized Traditional Peak mode for compressors (Singleband, Multiband) and Natural Dynamics.
- Fixed several bugs in the declipper -> output sounds better
- Scale added to meters
- Added zooming in/out to waveform displays, optimized the code, and made it possible to turn the display off
- CPU load for moving mouse over Bands or Equalizer displays greatly reduced
- Compressor: Peak mode replaced by Traditional Peak, RMS by Traditional RMS; RMS compatiblity mode available for old presets (only thing it does is raise the thresholds by 1.75 dB). Code is further optimized.
- Improved limiter attack and release behavior. See new 'Limiter maximum release' slider. (Difference is pretty big, the resulting signal is much tighter and pumps less; if I only use the limiter it's also about 0.75 dB louder than before with the same peak level).
- Improved multi-touch screen handling
- New version notification: Removed from GML plugin
- Added R128 normalization to GML plugin version
- Improved VMware detection (added param, and let it be set to VMware, Native, Unknown - where Unknown is automatically changed to either if it can be determined reliably.)
- Metering: MPX power added
- BS412 memory usage reduced
- Added MULTIPATH protection settings. Now similar to Stokkemask but with some settings not configurable. Tests needed...
- Added hysterisis when changing buffer size to avoid (or at least reduce) Juli@ driver crashes. If the buffer size is changed, only one restart is performed per 250 ms. Change was needed to avoid Juli@ ASIO crashes, but I've implemented it now for all input and output methods. Waiting for test results Note: This is a workaround to reduce the chance of an ASIO driver crash caused by an error in the Juli@ sound card driver. It greatly reduces the chance of crashes but doesn't (and cannot) completely protect against it.
- Added sound card restart behavior in case of driver errors. No guarantee that it works (because I don't know if the problem that was reported by Storm905 viewtopic.php?f=2&t=5054 was caused by what I think it's caused by) - but it might.
- Added option to receiving a stream via VLC, instead of using an external player and virtual cable.
- Added FM transmitter synchronization to stand alone version
- Added "Power Bass" mode to AGC. Makes bass far more constant and stronger. Based on feedback from Wouter Tietema and Jeff Prins.
- RELEASE
- Spend some time on making a new help framework...
PostPosted: Tue Dec 24, 2013 1:48 am
RELEASED! See viewtopic.php?f=14&t=5438 .
PostPosted: Tue Dec 24, 2013 11:25 pm
Getting ready to order a computer but before I do, is anyone using Win 7 32 bit with the Marian Trace Alpha sound card? All I need is for 1 person to tell me it's working great and I'm ready to move forward.
PostPosted: Wed Dec 25, 2013 9:51 pm
I suppose you have already seen (or heard from oldiesstation) this one: viewtopic.php?f=14&t=5442
PostPosted: Thu Dec 26, 2013 3:42 am
Yes, I saw that Hans. 42 people have looked at the post and apparently not 1 of them is using ST with the Trace Alpha on Win 7 32 bit--nor do any of the 42 know anyone who is. Appreciate the attempt to help Oldiesstation :)
