Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 126 27 28 29 3059 Next
PostPosted: Mon Mar 21, 2016 1:00 pm
Hm, I've made a hack-version where you can enable and disable some things and also try out a different reconstruction algorithm. If you want to test, you can find it here. Otherwise, if you can send me some recordings (or links to them) and tell me where you hear it, I can try it out myself.
Windows stand alone: http://www.stereotool.com/download/ster ... 85-046.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-046.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-046.dll
I'm suspecting 2 things that could be causing it:
- The reconstruction algorithm. So, now you can choose another one
- The algorithm that detects and fills MP3 holes might switch on and off too quickly. You can bypass it, that will add audio everywhere.
PostPosted: Mon Mar 21, 2016 1:28 pm
Thanks Hans, I am trying your hack version beta right now. Check your pm for two links to videos which you can try for yourself.
Another quick listen: the 'no protection' hack seems to make artifacts worse, while I'm not too sure about the 'alternate reconstruction' yet?
Might be worthwhile doing some measurements.
PostPosted: Mon Mar 21, 2016 2:37 pm
Ok, great. Effect is very clear on this. I do prefer the sound with the Delossifier enabled, as long as the top part isn't reconstructed. I've also tried using Absolute Highs to restore the highs, but it still sounds really bad, probably because the source material is so horrible.
What I will test: Dynamic detection of peak frequency in the MP3 file, and restoring upto that frequency. I don' t know if that's a good idea but I'll add a setting for it.
The old restoration method seems better than the new one. But I need to do more tests to make sure. Also, for the new one, Strength needs to be set lower (!) about 3 dB lower, so for the default 141%, you need 100% for the new method.
Edit: I see some other things that aren't working exactly as they should. Will try another way of determining how much reconstruction is needed as well.
PostPosted: Mon Mar 21, 2016 3:11 pm
Dear hvz,
When do you think to have the software compliant with 384Khz sample rate?
Im using 67Khz and 92Khz SCA subcarriers in my system and the 92Khz subcarrier with the 192Khz sample rate gets very distorded.
Thanks.
PostPosted: Mon Mar 21, 2016 6:24 pm
really like it very much. if the pitches can not be reconstructed now from the cut edge, then it sounds really good. But the alternative algorithm I find not so good! but the hack with the "no protection" I also find interesting. just in bad mp3 sounds I find very good.
thing I have occurred overnight: you could in the "absolute highs" exactly contrary, so add the high frequencies? So the automatic determination of the frequency, at which the pitch is to be completed? then the two filters would super cooperate.
PostPosted: Mon Mar 21, 2016 7:48 pm
@near05: I'm working toward that now. Next build will detect max freq and lower it quickly after a spike. Only disadvantage is that after a spike the highs stay there for a moment. On not extremely low bitrate files I like what it does though. It does fill holes on top but if they are big it dials down, which seems to avoid sounding distorted a bit. Building now!
PostPosted: Mon Mar 21, 2016 11:58 pm
7.85 BETA047
Windows stand alone: http://www.stereotool.com/download/ster ... 85-047.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-047.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-047.dll
CHANGED:
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- MP3 Propaganda - Duel way too much highs generated on default settings!
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?)
- Exciter: Add auto-adjust HPF frequency
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Resampler: Predict effect and compensate for that.
LATER:
- O skin
PostPosted: Tue Mar 22, 2016 1:28 am
Dear hvz,
Thanks.
Hm, not really looked into that at all yet. It's not a trivial change, and I don't think there are a lot of people using SCA2, who also have a 384 kHz capable sound card...
PostPosted: Tue Mar 22, 2016 11:04 am
It seems the "Voice Protection" setting of the classic multiband produces distortions (especially with piano instruments). The same settings sounds clear with Stereotool 7.03.
Here is a download of an example piano track:
http://ocremix.org/remix/OCR02928
The attached config produces distortions with 7.84, not with 7.03 - especially the loud part of the track beginning @ minute 3:16. The distortions dissappear when Voice Protection is set to zero.
viewtopic.php?f=14&t=7262&start=100#p33091
Still have the same problem with the current beta.
I illustrate it with this .WAV:
http://www.mediafire.com/download/4qdax ... _ReMix.zip
It contains the following clips: Original, processed with 7.03, processed with current beta, difference between both clips, processed with current beta without voice protection.
The difference clip shows the added distortions very clearly.
The tops seem to be "flatter" now in the current version (above current beta, below 7.03):
Last time when I compared the difference appeared to be in the singleband compressor that you were using at the end. Can you try what happens if you disable that?
PostPosted: Tue Mar 22, 2016 4:33 pm
What's that all about, particularly the first point?
