Post new topic  Reply to topic  [ 287 posts ]  Go to page Previous 125 26 27 28 29 Next
PostPosted: Sat Feb 22, 2014 11:26 pm
Everything works fine expect RDS, with 5 texts all 3s time in loop sometimes freezes for about 10s or even more and no data encoding (using stream via vlc at the moment)
Urban Junglist
PostPosted: Sat Feb 22, 2014 11:48 pm
I don`t know if this is easy but Enabling/Disabling the Normal Output or Others outputs must NOT cause the restarting of FM output.
May be a checkbox for "Non-interruptible" FM Output
PostPosted: Sun Feb 23, 2014 2:07 am
I have just compared the latest beta (036) against version 7.40, and the RDS output is nearly identical (the difference is that I have added some performance optimizations which also reduce rounding errors in the stereo pilot and RDS calculations). The audio is very close (a few tenths of a dB difference in some frequency areas).
Anyway, the RDS signal is as good as identical - which means that the texts that are transmitted are also. Can you send me the RDS text string that you are using?
PostPosted: Sun Feb 23, 2014 2:08 am
Not that easy. Anyway, I am planning (don't know yet when) a big rewrite of the sound card and audio inputs and outputs code. This might be included in that.
PostPosted: Sun Feb 23, 2014 9:56 am
When I testing earlier versions don't pay same attention to encoding RDS, so I don't know maybe it present in other beta
Once I already noticed something like this, I'll try to repeat issue one more time for some details.
Urban Junglist
PostPosted: Mon Feb 24, 2014 5:37 pm
Based on my own tests and feedback that I've received so far I'm guessing that version 7.41 is at least as good as version 7.40. So I want to 'upgrade' version BETA741-036 to a Release Candidate.
Did I miss anything?
PostPosted: Mon Feb 24, 2014 6:52 pm
Look on the list with "to be done" . If you fix all things , then release candidate turns into release :)
PostPosted: Mon Feb 24, 2014 7:40 pm
i think it is ready to release
PostPosted: Tue Feb 25, 2014 4:31 pm
This is the best one so far, not sure how you can improve on this.GR8 job Hans.
PostPosted: Tue Feb 25, 2014 7:29 pm
Happy release !!!! :)
