Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 125 26 27 28 2943 Next
PostPosted: Mon Aug 29, 2016 4:12 pm
If you downloaded right when he posted, he had the wrong links, and you got broken 29 again.
Still recording Hans ??? i have no ouput.. When i disable the Advance clipper i have sound
PostPosted: Mon Aug 29, 2016 4:15 pm
And you were right!!!! Its ok Now!
Sexy Girls in your city
PostPosted: Mon Aug 29, 2016 4:39 pm
No crash here at startup in very latest beta - stand alone
And i`m glad that will not have STS licensing (may be you mean that with SST at the list of fixed things).
PostPosted: Tue Aug 30, 2016 10:38 pm
I have the feeling that Declipper is not OK. When i enable it, it makes the music to sound like old cassette deck with bad azimuth
Anyone hear this too ?
There is a problem with Composite clipper may be , when i enable it - it goes a huge CPU load and buffer is restarting every few seconds - is not like this in 8.00
PostPosted: Wed Aug 31, 2016 12:01 am
Not seeing that here. Do you know in which beta this started?
PostPosted: Wed Aug 31, 2016 6:59 am
I don`t know , just test it on this last 29 . For sure, i check it on release 8.00 and it`s not like that (both problems).
I can make a record if needed or if helps
Here is a record of Declipper problem - from the beginning is ON, then i turn it OFF (you can clearly hear it) and then i again turn it ON (again clearly you can hear it)
https://www.sendspace.com/file/vzngc8
For high CPU and composite clipper, i`ll make video later.
And also this meters lag/delay is so annoying
PostPosted: Wed Aug 31, 2016 9:33 am
Hm that does sound bad! Can you send me your settings, because I don't hear anything like that here!
Which meter lag/delay?
PostPosted: Wed Aug 31, 2016 11:28 am
All meters above the scopes . All have a delay in response about 1.5-2 seconds - like that area of ST is working behind/after the scopes .
Scopes are OK.
Settings attached...just load them and enable the Declipper from the checkbox "Enable" only - by default it`s not enabled.If needed - wait a couple of minutes ( let`s say 5-10 ) and listen from normal output ... de-emphasised for example.
I now remember that Input without processing is still bla bla at higher speed :) and buffer goes empty
The strange thing with the Composite clipper is when i enable it - my hard drive starts to "TRRRRRR" - operating , but i don`t know what is doing ?!
EDIT: Found what is doing - it`s writing some wav.wav file in C:\temp !
Preset.rar [10.9 KiB]
Downloaded 231 times
PostPosted: Wed Aug 31, 2016 11:49 am
Ow, you must still have BETA029, that was a problem and I fixed it in 030! (wav.wav)
PostPosted: Wed Aug 31, 2016 11:54 am
oh, i didn`t kno it was replaced by 30 in the last beta post. Alright will change it
