RELEASE CANDIDATE
Windows:
Winamp version:
http://www.stereotool.com/download/dsp_ ... 25-026.exe
Windows stand alone:
http://www.stereotool.com/download/ster ... 25-026.exe
Windows VST:
http://www.stereotool.com/download/vst_ ... 25-026.dll
Windows command line:
Linux:
Linux stand alone:
http://www.stereotool.com/download/ster ... ETA725-026
Linux command line:
Mac:
Mac stand alone:
http://www.stereotool.com/download/ster ... 25-026.zip (requires JackOSX)
Mac VST 32 bits:
http://www.stereotool.com/download/ster ... 26.vst.zip
Mac VST 64 bits:
Mac command line:
Fixed previously:
- Try to build Mac 32 bit VST version with latest GCC compiler for performance
- Fix low latency ASIO sound card bug introduced in v7.24.
- Wait for last 2 Bojcha presets
- Adjust new FM preset BS412 levels
- Adjust Generic levels of new presets
- Add presets
- Mac: VST: Simple workaround: Simple GUI with "Show Stereo Tool window" checkbox. Also has an (unplanned) advantage: Window is resizeable. Might even be a good idea to support this in Windows as well!
- Mac: VST: Why doesn't the new window open in a separate window? Other windows (such as About) do...
- PC: Copy ASIO per-output channel settings to main ASIO screen.
- Remove pre-emphasize output
- Update version number
- Mac: Try bigger block size when sending data to screen (eldoradofm). -> Big difference, will change it. Also for Linux?
- Bob Hawkins built-in preset crashes
- Flat Frequency Response: Built-in presets use default value, should use conversion function.
- MB default frequencies on startup incorrect
- Default settings for ND -> Use latest from Bojcha based on JesseG's
- Fix Limiting display (must show dB's).
- Limiter: Fix (check) limiter
- Limiting works MUCH better with no lookahead - seems to use the smoothed signal when using lookahead. Remove that and perform some smoothing in backward direction (probably based on drop speed) to remove crackle.
- Added Release Inertia
- Improved limiter: Flatter frequency response, better behavior at low frequencies, more accurate level measurements, tighter (Bojcha, do you still hear the distortion from the previous beta? If so I can smooth things a bit more)
- Added Traditional Peak detection mode to compressor; this mode should not be used unless you have a lack of CPU power -> Brian, I think with this setting the new multiband compressor will perform about the same as the old one.
- Hangup when pressing Natural Dynamics in bottom display
- ND license incorrect
- AZIMUTH default settings: viewtopic.php?f=15&t=4875
- Phase rotator: Change name "As early as possible" (unclear!) and hide in most modes?
- Organize ND settings better
- Fix loading existing presets (Gamma values, "As early as possible" etc.)
- Split ND settings in to GUI modes
- Remove old ND implementation (saves memory and makes STS files smaller) -> 8 MB less memory usage
- Multiband: Improved Flat Frequency Response. Good values seem to be between 0.50 and 0.60 (depending on other settings!)
- Multiband: Added Attack and Release Gamma. See below.
- Phase rotator: Added checkbox to place it at the start of the processing chain (just before Natural Dynamics)
- Multiband/Natural Dynamics: Cleanup small spikes in Flat Frequency Response graph.
- Multiband/Natural Dynamics: Improve flat frequency response further.
- Mac: Default priority value to 46.
- Mac: Menu bar with Close APPLE+Q -> wxEntry exits but rest of software doesn't -> crashes.
- Mac: Cleanup named semaphores on exit
- Mac: RDS binary values
- Multiband/ND: Flat frequency response: value automatic conversion. ((v / .58) ^ .5) * .58
- Decide to which license to link ND -> Now linked to Declipper
- MB Knee does not work -> Yes it does...
- Linux: Test if everything still works. -> Yes, some small fixes were needed. Also removed printing to screen in Jack loop (bad!)
- Compressor: Place Gamma somewhere logical without making the interface too crowded.
- Display ND in bottom section
- ND handle changing number of bands
- Mac: Add auto-generating of .zip file with proper plist.
- Mac: Add icon
- Changed ND default settings (experimental!)
Remaining:
- Maybe add J-Type as BS412 preset as well
Later:
- ND artifacts band 1 (JesseG) - is this still an issue with larger drop times? -> Later
- Compressors: Add Reverse Release to improve start of loud highs -> Idea might be good but it doesn't work this easily. Postpone.
- Try to reduce MB/ND volume measurement CPU load. Maybe ignore some bands if there's nearly no signal there etc.
- Multiband/ND: Flat frequency response: Add separate settings for each crossover?)
- MB bands limiting display - Really difficult to fix (without increasing CPU load); it works fine without band coupling, and shows the actual reduction level if band coupling is used. So keeping it like this for now...
- Mac: VST: Child window support. Difficult... Maybe later! Not needed, current solution seems ok.
- Mac: Cursors not supported. (Keep like that for now).
- AGC behaves bad: Different speeds at different locations.
- ND boosts highs in Dragana S track - should not do that-> later?
- Band coupling separate settings per crossover -> bit problematic, can this be postponed?
- MB Gamma and Inertia default values - but without changing existing presets
- Somehow try to estimate Attack/Release vs. Gamma/Inertia?
