Yes, but there is never pre-emphasis (FM broadcasting) without de-emphasis (FM receiver).
I was going to say that! lol
Yes and No !
This option in Loudness section applies pre-emphasis and de-emphasis !
http://www.claessonedwards.com/forum/vi ... ?f=5&t=172
So sending an FM pre-emphasised signal to my receiver would be a bad idea. Also the loudness only goes up to 30, while FM gives 50 & 75. higher values = more emphasis?
Lets clarify that I am not using the pre-emphasis option in FM, I just like the way it boosts the high freqs.
Cause the replies I've been getting, though very interesting and helping me understand these things are assuming that I'm using the FM pre-emphasis.(at least thats what I feel like) I tried it, and i liked how "clear" the audio was but I'm not using it. I just pushed the EQ for the last 4 bands higher instead, gives me the same result.
Even if you use low CBR 128 (old standard) then we are talking about filtering frequencies above 15.5 KHz.
But with higher VBR LAME this is absolute irrelevant in practice.
So
this is not the problem of MP3 encoding.
The questions is:
What happens from 1KHz to 14 KHz ?
Compare newer LAME versions @ CBR 128 with LAME
3.93.1 !!! - so newer is not automatically better !)
If all the music files on the internet were VBR v0 I'd be a lot happier. If they were all flacs I'll be content with life. xD
If you're talking about audio quality newer might not always be better, but there should be an improvement in size. Aren't Mp3s about size? Audio quality wise to me its okay and preservation wise it sucks.
Ok, it is not wrong to have higher frequencies (up to 20 KHz or more).
But this is less important, because most people older then 35 cannot hear frequencies above 17 KHz (and many younger people today have already serious ear damages).
So theory (or internet propaganda in certain audiophile circles) is one thing.
But reality is another cup of tea.
Just hit 18 and I wouldn't say i have perfect hearing but I can still register 20khz.
Would you say that the higher frequencies still give the overall music some type of "life" even if you can't hear the higher frequencies.
Looking at speakers, they vibrate (I like to use technical words to sound smarter. really. xD) differently with different signals so if you cut off a whole section say from 18Khz and up those signals are not sent to the speaker, which then doesn't vibrate at those frequencies. To me that sounds like a broken instrument.
The difference between theory and reality is what makes any type of audio work an art, its not something you can just set to 11 and expect the perfect sound.
Funny thing I was drinking a cup of tea when I read this.
Hey michi if you want to PM me with a reply or start a new thread that'll be cool. This is taking up a lot of room here when it really has nothing to do with Stereo tool news xD
