Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 476 posts ]  Go to page Previous 124 25 26 27 2848 Next
PostPosted: Wed Apr 15, 2015 7:30 am
Thanks for you post RobertSack. Interesting reading! I guess that many of us have tried that 'exaggerated' sound before realising the pitfalls.
At one point, there was quite a bit of talk of the differences between the Stereomaxx and 222A from their individual proponents / fans?
PostPosted: Wed Apr 15, 2015 11:23 am
Thank you, 2Sense, for your Kind words.
The latter one is in deed a "talk-about" :-)
At first Hans`s ACR- Stereo is better than the original 222A.
With the original unit you only have one control:
You have to turn it to about "4" to hear something of ist effect, but if you go only a bit above this, you hear unwanted side- effects: (I assume you know the working principal of the 222A)
-you will get a Kind of "pumping", you hear the unit working and
-the unit emphasizes or accents wrong parts/passages.
ACR- Stereo in ST is ultra- tunable. So with an invest of a bit time (in difference mode) you can achieve that only the parts you want are empasized and so create a special kind of punch and wideness.
It's more consistent than the 222A.
Another Point is, with more multiband compression you decrease the spatial Image with. So, in this case more enhancement is needed and the Stereomaxx maybe one of the better choices.
This maybe one of the reasons why both types of enhancement are available in the newer Optimods in addition to the AGC Sum/Dif- Matrix- Mode.
Regards,
Robert
PostPosted: Wed Apr 15, 2015 3:26 pm
For the "huge effect" in a PC domain, one can use Spartacus vst plugin - though it has no width-limiter as far as I remember, so be extremely careful with that.
But I really don't see any point - ST has a decent stereo enhancer.
Having said that - I used to play with those "concrete domed stadium-like" stereo effects - this incorporated "stereomaxx-style" stereo enhancer and FFT stereo widener - maybe this is something evrenselFM is talking about?
http://www46.zippyshare.com/v/rHd0mYKV/file.html
http://www46.zippyshare.com/v/bjHsrxsu/file.html
http://www46.zippyshare.com/v/st7b4eqR/file.html
http://www46.zippyshare.com/v/uZoIfrxt/file.html
http://www46.zippyshare.com/v/USkZaTk3/file.html
http://www46.zippyshare.com/v/mGW6VHk9/file.html
http://www46.zippyshare.com/v/YAfjYeBz/file.html
http://www43.zippyshare.com/v/QUQpIiUZ/file.html
Somehow "stereo image" processing in ST sounds a bit different though.
PostPosted: Thu Apr 16, 2015 1:44 pm
Hi guys !
Hans has refresh my preset last summer but there have been updated stereotool from last summer 2014.
What do you think about this preset ?
Actually the preset is on version 7.60
It is possible to refresh this ?
Maybe we have a problem with bass, extremly loud sound, probably an error of configuration in Advanced clipper...
an soon the next version 7.70 coming and probably refresh our sts file.
We search a extremly loud sound for french radio.
actually in France most radio have a PMux near 9 / 9.5 dBr
Thanks a lot
top080415.sts [61.04 KiB]
Downloaded 257 times
PostPosted: Thu Apr 16, 2015 10:42 pm
HANS PUT MY PRESET
http://www14.zippyshare.com/v/nLj9VrKR/file.html
This preset very very stereo :)
hey VFR750A45 your prest to base no good ! and like mono sounds
PostPosted: Fri Apr 17, 2015 11:24 am
can you help us to configure correctly my preset ?
Thanks
PostPosted: Fri Apr 17, 2015 11:34 am
HANS PUT MY PRESET
hi !!
good sound !
And what is the value of PMux ?
Thanks a lot
PostPosted: Fri Apr 17, 2015 1:40 pm
Think its not the right place to discuss settings and presets...
PostPosted: Sat Apr 18, 2015 12:12 am
yes i move to the appropriate topic.
PostPosted: Sat Apr 18, 2015 11:00 pm
RobertSack you dont understand me
ı mean no to stereo left and right insturiments and vokal ı want to hear
maybe we change sound mixer can you say good sound mixer name ??
