Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 124 25 26 27 2876 Next
PostPosted: Mon Oct 15, 2012 4:33 am
I tried beta 16.
Good news: Essentially the same CPU load (within 5%)
Not really bad news, just a preference: I really liked the previous UI's capability of providing an at-a-glance overview of everything going on, and if you need to know more, you drill down on the individual component. This UI makes you have to "work harder" if your preference is to see a high-level view first.
For new users I think it was really way too much. And it was getting more and more problematic to make it fit on a (smaller) monitor. But are you talking about the old main window or the subsections? Because currently in the main window you can actually see *more* than before - if you choose the bottom view with meters.
PostPosted: Mon Oct 15, 2012 5:52 am
I tried beta 16.
Yes, the main window, but I realized that by clicking on the nondescript right arrow, it changed the lower portion of the window.
Suggestion: At least put some sort of label on the thing...
Bug: Every now and then the X to close to tray does not respond, and when that happens, eventually the entire interface is non-responsive, with only minimize and maximize working.
DSP version (Winamp). Windows XP SP3.
PostPosted: Mon Oct 15, 2012 12:48 pm
Excuse me... is this the new Skin on ST???? O M G.... i didnt see latests beta cause i thought it was the web based project, not the overall skin..! OMG...
I am lost .... :( I want the last skin back :'(
Its very nice. Congrats... (but i am used to last one :( )
Sexy Girls in your city
PostPosted: Mon Oct 15, 2012 2:59 pm
I'm still used to the last one as well... But this new one should - especially for new users - be MUCH more organized and clear. (For example, just look at the old Loudness window and then at the new interface.) At least that's the idea. If it's not, please let me know why!
PostPosted: Mon Oct 15, 2012 3:52 pm
I Agree its more organized.! But i was used the old one.. and its a bit confused with the Load new preset. I got confused what to load :p
I know its the first time i see this new Gui, i will get used to this as well.. Need Time.
PostPosted: Mon Oct 15, 2012 10:59 pm
http://www.stereotool.com/download/ster ... 33-017.exe
http://www.stereotool.com/download/dsp_ ... 33-017.exe
Some bug fixes and small improvements. Also more skinnable stuff.
- Meter background with image (skinnable)
- Different skin for bottom
- Make volume red for overshoots
- Synchronized input/output level meters and added pre-emphasis display
- Redesign RDS display (Bojcha's idea: http://i.imgur.com/6lUjV.png ) (Not completely done, might add other things later)
- FM hiss display in overview
- FM hiss display still needs to be converted to the new interface.
- Check if it's possible to make the button sizes less different (change max zoom depending on window size, so the buttons don't get huge on a small window but still fill the screen on a big one). Not really great, but there are some more limitations than before now. Unfortunately the only effect is that the buttons don't fill the screen horizontally.
- Add limitation to horizontal aspect ratio.
PostPosted: Mon Oct 15, 2012 11:22 pm
Default skin images for version 017 (there are quite a few new images in it):
http://www.stereotool.com/download/SKIN.zip
PostPosted: Tue Oct 16, 2012 12:25 am
B017. Dragging the window resize handle to minimise the height of the window to the smallest size, crashes the GUI every time. Win XPSp3.
PostPosted: Tue Oct 16, 2012 12:37 am
Known bug.
PostPosted: Tue Oct 16, 2012 1:42 am
Yes if you make it too small it crashes. I've also noticed a few hangups tonight, not sure yet what's causing that.
