7.85 BETA043 (WiFi suddenly started working again, after using my laptop all day at a transmitter tower ?!)
Windows stand alone:
http://www.stereotool.com/download/ster ... 85-043.exe
Winamp DSP:
http://www.stereotool.com/download/dsp_ ... 85-043.exe
Windows VST 32 bit:
http://www.stereotool.com/download/vst_ ... 85-043.dll
CHANGED:
- SPA remove monthly popup
- Added other optimizations
- Exciter:  Improve start of filter (less steep!)
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Add Polar stereo
viewtopic.php?f=16&t=6233&p=33031#p33031 - Feedback so far is that it works fine
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?)
- Exciter: Add auto-adjust HPF frequency
- MP3 sandy sound (caused by bad detection?)
- MP3 Propaganda - Duel way too much highs generated on default settings!
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
LATER:
- MB: Add voice volume protection, don't allow mid bands to drop below surrounding (to some extent), protectes voices and it might help to replicate the sound of certain other processors
- O skin
