Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 123 24 25 26 2776 Next
PostPosted: Fri Feb 23, 2018 9:17 pm
It sounds simple, but making a compressor only work when there's something to actually do is a lot harder than it looks.
Imagine what horrors employees have to endure when this process takes place in the vicinity.
PostPosted: Fri Feb 23, 2018 9:19 pm
My heart goes out to you. I'm across the world on Facebook Messenger, and it is already dangerous enough...
PostPosted: Sat Feb 24, 2018 2:55 am
Found the cause of the Basstardizer issue. It was somehow mixing up the lookahead data of the two channels. Fixed now (next build).
PostPosted: Sat Feb 24, 2018 2:56 am
Mwahahaha!!!! Well, you're at home and I'm still here at 2:55 AM. So... I still think it's worse for me :)
PostPosted: Sat Feb 24, 2018 3:53 am
Update: Max Release Speed appears to work now.
Why release is a problem:
Attack
Let's say you're at absolute silence (sample value 0), the threshold is set to sample value 100, and some audio comes in at sample value 1000. Then the difference in level is a factor 10, and once we start moving, that decreases. Great.
Release
Now release. We have had a whole bunch of samples at 1000, and suddenly the input level drops to 0. The relative difference between 1000 and 0 is infinitely big... And even if we start moving towards it, the distance stays infinitely big. So, we keep moving up at an infinite speed.
Solutions
Option 1: Use max release speed. That will work in the next beta.
Option 2: Use a constant minimum level for sample values below that value (which could, but doesn't have to, be the threshold value). That would work, but it creates nonlinearity: The compressor moves the same regardless of whether we're at 2 dB attenuation or 200. That would no longer be the case with a constant offset.
Option 3: Use a moving minimum level for sample values, relative to the current attenuation level. I will add that asap, it will hopefully work slightly better (smoother) than option 1, which causes the speed to abruptly stop increasing above the max speed. Option 3 should have a much smoother transition area.
A new build with working option 1 is running now.
PostPosted: Sat Feb 24, 2018 10:02 pm
Don't attempt to run this preset until at least beta 30 comes out. However, it shows a working template for using relatively high values of max release, but enough to keep you out of trouble. Rather than worrying about a specific dB/sec, value. I focus on the numbers in the backend.
In multiband 1, I'm using 36 everywhere. That corresponds to a multiple of about 1.5 compared to the natural fall rate for a compressor. What I mean by that is that if you have a 2000ms release, then that has a natural fall rate of 6dB/sec (from 12dB of gain reduction). Using a 36 in the file for max release, would allow that compressor to release at a maximum rate of 9dB/sec. I went a little higher in the AGC, but not much. I use 38 (1.6 multiple) there.
I find these values are a nice compromise between letting the compressor be fully dynamic (and getting wild release), and restricting them to their natural rate, which robs you of some of the dynamic properties of symmetric mode.
Anyway, hope this proves helpful.
NewRMS-High-0-02s.sts [113.44 KiB]
Downloaded 214 times
PostPosted: Sun Feb 25, 2018 12:09 am
The build from last night was still broken (Wes found that before I even posted it here). New build has been running for a few hours now and should be ready in about 1-1.5 hours.
PostPosted: Sun Feb 25, 2018 1:12 am
Stereo Tool 8.55 BETA030
NOTE: KNOWN ISSUES:
- Symmetric modes are visible for Digital compressor but is not (and will not be) implemented!
Windows stand alone: http://www.stereotool.com/download/ster ... 55-030.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-030.exe
VST: http://www.stereotool.com/download/vst_ ... 55-030.dll
- Max release speed fixed (*)
(*) I have added some code to generate a pretty bizarre curve (which does give the correct behavior). I want to get rid of this code, the behavior could very slightly change when I manage to get rid of it.
OLDER CHANGES:
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
NOTE: Bass EQ
- Symmetric modes are visible for Digital compressor but not implemented!
- Test NanoPi
- Classical preset
- NAN seen when switching to new compressor mode which also doesn't get recovered - silence afterwards. (Peak mode recovers it though).
- Optimize new compressor mode
- Make 9/9sg pilot generation smooth for external feeds for DARC etc.
- Bass mono fiter to reduce multipath
- Is pre AGC affecting audio levels? (With BS412) -> Not specifically for BS412, but it slightly reduces the level even if set a lot higher. Probably needs some offset.
- Aanvraag uren
- AM streaming output
- Add AM presets
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
New compressor mode info:
Important: The CPU load is really high right now. I will optimize it later.
Also important: You can't just enable this new mode and expect everything to be fine without changing the settings. For small level differences there won't be a difference, but there will be for big differences. You'll definitely notice the slower attack on big level jumps.
PostPosted: Sun Feb 25, 2018 6:08 am
What actually happens when selecting Symmetric RMS in Digital compressors in the last 2 betas?
PostPosted: Sun Feb 25, 2018 7:27 am
That "fade in" issue at the beginning of tracks still seems to be present. :|
