Post new topic  Reply to topic  [ 286 posts ]  Go to page Previous 123 24 25 26 2729 Next
PostPosted: Sun Jun 06, 2010 4:49 am
The AGC #2 settings are stored now (NOT YET for VST plugin!)
Performance is now slightly better than in version 5.00.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... ETA006.exe
Stand alone version: http://www.stereotool.com/download/ster ... ETA006.exe
VST version: http://www.stereotool.com/download/vst_ ... ETA006.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... ETA006.dll
Command line version: http://www.stereotool.com/download/ster ... ETA006.exe
Edit: Saving in VST version works now...
PostPosted: Sun Jun 06, 2010 11:44 pm
So could this one maybe be released, or do you have some more things to work out?
PostPosted: Mon Jun 07, 2010 1:17 am
This two AGC's can be well tuned in much different ways .. i think Hans will leave it for next version ..
My recommendation is to just make AGC window as much as possible small. If possible to make one Meter for both AGCs.. or something.
Tomorow i'll chack that Pentium III crashing. I think i have one at service.
I have other small ideas for ST filters .. but i'll not present for now.
btw .. sometimes meters from AGC and multiband window disappears when it is opened and you press Ctrl+M or "Show Desktop" icon.
PostPosted: Mon Jun 07, 2010 2:01 am
Yes, I want to release version 5.10 soon - it's a lot better than 5.00 so I think it's getting time to release it.
Wouldn't that make things more difficult to configure? You can't see separately what the 2nd AGC is doing... In the main window, I do combine the two (due to lack of space). If you don't use both AGC's it doesn't matter whether there's one display or 2 - and if you DO use 2 AGC's you need to see them separately...
PostPosted: Mon Jun 07, 2010 2:08 am
I've replaced the "target output level" of the 2nd AGC with an 'AGC gain control strength' slider to make things easier to configure.
Changes:
- Replaced the slider. Set it to '1.00' equals setting 'target output level' for the 2nd AGC to the same level as the first in previous versions. (Setting it to 0.5 corresponds to setting it to half the target output level of the 1st, etc.)
- Previously, turning on 2 AGC's reduced the output level. Now there's a correction factor used, such that the COMBINED effect of both AGC's leads to the selected 'target output level'.
So, the 2nd AGC doesn't change the output level anymore, just the type of gain control that takes place.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... ETA007.exe
Stand alone version: http://www.stereotool.com/download/ster ... ETA007.exe
VST version: http://www.stereotool.com/download/vst_ ... ETA007.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... ETA007.dll
Command line version: http://www.stereotool.com/download/ster ... ETA007.exe
Note: If you load an existing preset created with the previous version, the 2nd AGC level will make no sense at all, you'll need to reconfigure it.
PostPosted: Mon Jun 07, 2010 7:49 am
Guys .. I agree that due to the settings you can straighten out the problem. But until it comes out only at the expense of narrowing the dynamic range of sound. It sounds flat and thin ... Not really .. but there is a flat sound. While the best quality is from Betta 28 May :geek:
PostPosted: Mon Jun 07, 2010 11:26 am
I checked the updates since the May 28th version to see if I could explain this, but I would expect the opposite of what you're describing!
BETA
28 may version!
BETA2:
I just found a bug in the AGC that's both causing a mid/high frequency volume drop in the "Beyonce - Video Phone" track, and causing the volume to go down more for loud vocals in the Celine Dion song Improvement!
- AGC behavior is changed around the place where the AGC started to reduce the volume before. Now it starts a lot earlier, but the effect grows smoothly. This does mean that input tracks around the configured target output level will come out a lot softer now! But at least all tracks at the same input level should now come out at the same output level. This also impacts the output RMS volumes: They are now about slightly more apart if the input level is different. (But I think the benefits outweigh this small disadvantage). Should not change much. Around where compression starts it lowers the volume. But instead of suddenly starting to compress it now starts gradually
Changes are:
- No more bass added to band 2 (so it can now more easily separate from the lock to the band 1 level, Beyonce track is much better;
- level smoothing for input level near target output level (tracks around this input level with much dynamics came out far too soft before, now that has been greatly reduced).
BETA3:
I've uploaded a new version where you can control the stereo separation - at 100% it's identical to the previous version, at 0% the two channels are identical in volume (except when the difference gets too big and 'remove remaining peaks' starts to kick in). Improvement!
BETA3A:
Bojcha has sent me a PM a few days ago about reducing the up speed when the current level and target level are close to each other.
Until now, the volume increment was very fast if the volume was very low, changing with an asymptote to 100%.
I've now changed this; instead of an asymptote that ends at 100%, the asymptote now ends at the new target volume level at the current position (so if the level doesn't change much, the volume stays almost the same). Big improvement; sounds like Up Speed is lowered
Result:
- Volume of already compressed tracks is far more stable than before.
- Between voices, if there's not really a lot volume difference, the volume doesn't climb much, so it doesn't drop much when a new voice starts either.
- Relatively silent parts of tracks are not boosted as much as before.
- Big volume differences are handled similarly to before, which is good.
- And for the same track, the up speed is now identical regardless of the input volume (unless it's really low of course).
- For the same 'up speed' behavior, you might need to set 'up speed' slightly higher than before. (But I don't know if that's really necessary)
- Difference in dB ITU-1770 is a big higher now (unless you set 'up speed' slightly higher), but not that much (for the worst case situation, "Gimme Gimme Gimme" vs. very strongly compressed song, 1 channel, at default settings the difference increased from 2.1 to 2.8 dB; if you use 2 channels the difference is about 0.7 dB).
BETA004:
Fixed Loudness bug
BETA005:
Changed displaying up/down speed values
BETA006:
- Settings of 2nd AGC saved to disk
- Improved performance
BETA007:
Hm... Edit:
I just realized that the volume smoothing means, at low AGC output volume levels (strong attenuation), that the behavior is close to that of TWICE the input volume of before I switched to volume smoothing. Which means that the Up Speed works stronger, giving more compression-like effects. NOT TRUE
But... The other change (smoothly going to the new target volume instead of going to volume '1') should fix that, and make it even better than before.
That would mean that it gets WORSE in BETA2, and then BETTER in BETA3A. So this is also not true
This may also depend on the AGC input level - if there's not much attenuation taking place, and you have songs with much dynamics, I can imagine that they come out slightly flattened, even with the
PostPosted: Mon Jun 07, 2010 4:01 pm
Again! Orban, a standard installation of audio input level - 13.7db Audio output 0 dB !!!!!
Stereo Tool standard setting preset fm transmitter mild (Europe) standard installation of audio input level of 19.93 dB plus !!!!!!!!!!!!!!!!!!!!! Audio Output 0dB Why? Automatic level control reduces the signal? Why Orban works differently? The display Orban has always been no more than three sectors .. It means a low input sound levels. Why Stereo Tool not work like that?
PostPosted: Mon Jun 07, 2010 4:07 pm
http://www.youtube.com/watch?v=JOCGNXyN ... re=related Video!!!!!!!!!!!!!!
PostPosted: Mon Jun 07, 2010 7:38 pm
Soundfm,
i would like to know what you talking about.
On that very same video you can see threshold of -40dB dor AGC, so you ca put in + 30dB and still be "safe"
In Stereo tool same thing occures, even with more advanced setup. You have andvanced filters in orban and omnia too .. but you'll never see it!
Here is puicture for you.
Orban with Max possible input... you can see how AGC is makeing reduction ..
If you in same way put +30dBs in Stereo Tool .. same will happen. (don't be confused with upside-down metering.
I my standard StereoTool preset .. i have Preamp seted to around 20dB .. so with yous 13.7 i have just have more room in AGC, about 6dB. But again much depend on your input. Your Input is safe with -6dB peek! So you need that 6dB back + room for AGC to work.
