Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 122 23 24 25 2659 Next
PostPosted: Sat Mar 12, 2016 11:27 am
Beta40 Standalone crashes instantly on startup here :oops: Deleting the .ini-file in User-directory doesn't help...
PostPosted: Sat Mar 12, 2016 5:13 pm
For Standalone Beta 38 crashed continuously but beta 40 won't even open here.
PostPosted: Sat Mar 12, 2016 5:23 pm
Oops! There was indeed something wrong. Which didn't affect the plugin versions, but it did affect the stand alone. I'm rebuilding now.
PostPosted: Sat Mar 12, 2016 11:04 pm
7.85 BETA040
Windows stand alone: http://www.stereotool.com/download/ster ... 85-041.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-041.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-041.dll
CHANGED:
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031 - Feedback so far is that it works fine
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?)
- Exciter: Add auto-adjust HPF frequency
- MP3 sandy sound
- License check
LATER:
- O skin
PostPosted: Sun Mar 13, 2016 3:24 am
Hans, the new delossifer is really good! :-) Only the the bleeps...can I register?
In beta 41 I got a nan exception "second screen black hole" couldn't get rid of it, dsp version Win7 64, AMD 4 core.
The drawing of the new simple screen fails at the Natural Dynamics window. Gives a good overview b.t.w!
Still would have the feature to collapse the command window, only viewing the monitor part.
Thanks a lot!
PostPosted: Sun Mar 13, 2016 5:49 am
beta 41 standalone is working good here.
Windows 10 on an AMD phenom II six core.
PostPosted: Sun Mar 13, 2016 11:49 am
Thanks a lot!
Can you post a screenshot? And the nan message says second screen???
@registering: I first have to update my registration tool... I'm flying to Turkey tonight, maybe I'll do it during the flight :)
PostPosted: Sun Mar 13, 2016 6:11 pm
Sorry Hans, I can't reproduce the nan exception, it was second screen.
Just gave it another try, it's running fine now!
Have a good trip!
PostPosted: Sun Mar 13, 2016 8:21 pm
Screenshot of NAN error.
PostPosted: Sun Mar 13, 2016 10:46 pm
Ok, reproduced the NAN issue here. Will try to fix it on my flight to Ankara.
