Post new topic  Reply to topic  [ 433 posts ]  Go to page Previous 122 23 24 25 2644 Next
PostPosted: Sun Oct 12, 2014 3:50 am
FFFFFFFF indicates a memory alignment error - which in turn indicates either a compiler optimization bug or an error in me SSE2 code (limiter doesn't use SSE2 though as far as I remember).
PostPosted: Sun Oct 12, 2014 5:07 am
dsp beta 017 error,,,, when advanced clipper active ( running in radioboss )
PostPosted: Sun Oct 12, 2014 9:04 am
Will there be a VST beta version?
PostPosted: Sun Oct 12, 2014 10:52 am
Standalone version 17
centurion problem:
Also prelimiter problem confirmed, well 512bands cause problem. other bands no problem.
edit:
The error in centurion is in the declipper!!
Load that preset and disable declipper and the preset will work again. Did check all functions in stereotool and disabling the declipper made it work..
edit 2:
From build in presets and than reset all audio settings gives also errors
The Power of Sound
PostPosted: Sun Oct 12, 2014 4:21 pm
Have to test it on my core 2 duo.Hans, any feedback on limiter placement before or after MB?
PostPosted: Sun Oct 12, 2014 5:29 pm
Testing
Last Release VS last Beta
CPU 19% vs 15-16%
Weldone Hans... but i will KILL you :P :P cause i have bought new pc for ST last versions :P :P
Nevermind!!!!
Sexy Girls in your city
PostPosted: Sun Oct 12, 2014 9:22 pm
Exceptions testing this last beta.
Exception in: Modify_samples call internal (Exception 0xc0000005 at address 0x1369dde, read/write=0, r/w location=0xffffffff)
Restarting: NO
Restarting: NO
Exception in: ProcessingChain G (Exception 0xc0000005 at address 0x1369dde, read/write=0, r/w location=0xffffffff)
Restarting: NO
Restarting: NO
Restarting: NO
Restarting: NO
Restarting: NO
Restarting: NO
Exception in: ProcessingChain C (Exception 0xc0000005 at address 0x1291e69, read/write=0, r/w location=0x4e64)
Restarting: NO
Restarting: NO
Restarting: NO
Restarting: NO
Restarting: NO
Restarting: NO
PostPosted: Sun Oct 12, 2014 11:52 pm
Uh, what do you mean by that? Limiter placement before or after MB? In the compressors I have made a change a while ago which causes the compressor to respond as if the limiter was placed before it (it's not), to avoid very fast volume reduction if you have very loud sounds which also hit the limiter.
PostPosted: Sun Oct 12, 2014 11:53 pm
DSP or Stand Alone? And if stand alone: 32 or 64 bits?
PostPosted: Sun Oct 12, 2014 11:59 pm
I am using the Stand Alone version on Windows 7, 32 Bit.
