Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 121 22 23 24 2543 Next
PostPosted: Tue Aug 23, 2016 6:21 pm
I have to crashes with last beta and VLC input:
- 1st clicked bypass few times and ST just closed
- 2nd also clicked bypass few times and get blank not responding window
win10 64bit and latest VLC
Do you know if it's related to VLC?
I don't know, because tried only in that case..
Can you try without VLC? If it's VLC I cannot do anything to fix it (it could be in the latest update for example). If it's in Stereo Tool, without VLC, then I have to try to reproduce and fix it.
PostPosted: Tue Aug 23, 2016 11:17 pm
something wrong with this last beta.. i have Gaps, at all pressets.
What does 'gaps' mean? I don't hear anything bad, and as far as I know I haven't changed anything that could break something. Is 023 ok? Does restarting help?
Edit: Does "gap" mean that you get a period of silence after - say - 20 or 30 minutes or so? If so I might know what it is.
Are you using VLC? I just found out that there was a resampler bug when you use VLC due to the fact that many streams are sending data in bursts. Solved now by turning that off.
PostPosted: Wed Aug 24, 2016 4:16 am
Fixed:
Windows stand alone: http://www.stereotool.com/download/ster ... 01-025.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-025.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-025.dll
Known issues:
- White list IP's?
- CHECK CRASH with VLC - VLC related??
- Make new separate Presets class -> Export still needed?
DONE:
- Add Declipper main view
- Gain works again
- Type IP in web site
Later:
- Generate UIDs and use link
- Password for login?
- Run as a service
- Websockets? Later
PostPosted: Wed Aug 24, 2016 9:02 am
BETA025 crasht in Winamp
PostPosted: Wed Aug 24, 2016 9:08 am
Confirmed - cause is clear too. Will fix it asap.
Edit: Fixed (next beta).
PostPosted: Wed Aug 24, 2016 12:00 pm
YES Gaps are small moments of silent.! I still have... its like Cpu cant handle the ST anymore... and from 34% utilization goes to 19 with gap and then back to 34.
I did nt had that problem to previous beta.
This Gaps(1 sec) are every 5-10 sec period
PostPosted: Wed Aug 24, 2016 11:33 pm
Fixed:
- White list IP's?
Windows stand alone: http://www.stereotool.com/download/ster ... 01-026.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-026.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-026.dll
Known issues:
- Remove warnings
DONE:
- Gain works again
Later:
- Run as a service
- Websockets? Later
PostPosted: Wed Aug 24, 2016 11:34 pm
Do you still have this with the latest beta's (025/026)? If so, could you re-install an older one and make sure that it doesn't occur there? (Wouldn't be the first time that someone reports a bug in a beta which was actually caused by a change on their pc or in their settings... - and I have no idea what could cause this)
PostPosted: Thu Aug 25, 2016 5:20 am
When I activate this option, an exception is thrown
PostPosted: Thu Aug 25, 2016 9:11 am
Found & solved. Same bug was present in AM stereo downmixing!
