Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 121 22 23 24 2559 Next
PostPosted: Mon Mar 07, 2016 9:19 am
I'll build a new version in a few hours where I turned the one optimization that seems to cause most issues - and it also doesn't really seem to help performance (!) - off.
PostPosted: Tue Mar 08, 2016 4:39 am
7.85 BETA038
Windows stand alone: http://www.stereotool.com/download/ster ... 85-038.exe
Winamp DSP: ----://www.stereotool.com/download/dsp_stereo_ ... 85-038.exe FAILED
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-038.dll
CHANGED:
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- MP3?
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?)
- Exciter: Add auto-adjust HPF frequency
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- Put in Ben Liebrand settings for vinyl cleanup?
- Command line version doens't like long name (Antenne V. - see mail 2-3-2016 22:24).
- MP3 sandy sound
LATER:
- O skin
PostPosted: Wed Mar 09, 2016 10:10 pm
Looking forward to the release. This one is taking some time! :D
PostPosted: Thu Mar 10, 2016 11:08 am
Looking for testers!
For a new MPX streaming product, we are looking for radio stations that want to test it on a short term. If you are interested in MPX streaming and have an FM radio station, please send me a PM!
Note: It's currently all command line based, so if you want to participate in this test, it helps if you're at least a bit familiar with using command line tools.
Note 2: Currently only works with Stereo Tool!
PostPosted: Thu Mar 10, 2016 1:18 pm
I can be one tester :)
PostPosted: Thu Mar 10, 2016 6:55 pm
Before I signup for testing MPX streaming, some questions:
- what is the bandwidth needed for this MPX streaming ?
- in the future, will it work from within Stereo Tool or is it a separate software package (or a plugin) ?
- what is needed at the receiving side (transmitter site) ?
Frank
PostPosted: Thu Mar 10, 2016 6:57 pm
The Winamp plugin of the latest beta (038) is still not available:
PostPosted: Thu Mar 10, 2016 9:13 pm
Your new MPX streaming tool uses FLAC at 192 kHz sampling rate?
PostPosted: Thu Mar 10, 2016 9:40 pm
No...
@frlill: I'm sending you a PM!
PostPosted: Sat Mar 12, 2016 10:28 am
7.85 BETA040
Windows stand alone: http://www.stereotool.com/download/ster ... 85-040.exe BROKEN!
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-040.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-040.dll
CHANGED:
- SPA remove monthly popup
- MP3 sandy sound
- License check
LATER:
- O skin
