Post new topic  Reply to topic  [ 707 posts ]  Go to page Previous 121 22 23 24 2571 Next
PostPosted: Mon Feb 06, 2023 3:30 pm
On my side it`s happening every time i try to change from 5 to 9 bands.
Try select 5 bands, turn off AutoEQ, then close program. After start again, turn on AutoEQ again, then go to select 9 bands. It should appear this error. It makes it every time.
All this is with default settings for AutoEQ.
PostPosted: Mon Feb 06, 2023 4:49 pm
I received a file from MrKlorox and it reproduces here now. I'm looking into it. I found and fixed one cause but it's still happening.
Edit: Found a 2nd cause, not it works without issues. I'll run a build tonight.
PostPosted: Mon Feb 06, 2023 5:45 pm
Hi.
I've tested out Stereotool beta 10.02-43 on an Intel MacOS 11.7.3 in Wavelab 11.1. I cant see any plugin parameters, Just a blank screen.
When I revert to the latest official release of the plugin, everything is working fine.
Does anyone know if there is a stable version of the beta for MacOS/Wavelab? I'm moving over to a MacBook Pro M2 Pro computer in a couple of weeks and it would be great to have a working version for this too.
Thanks
Gav
PostPosted: Mon Feb 06, 2023 5:48 pm
Allright, will test it again, no problem.
PostPosted: Mon Feb 06, 2023 5:51 pm
Hi.
Thanks
Gav
Hello Gav, this should have worked. We'll put it on our todo list, so we'll check it shortly.
PostPosted: Mon Feb 06, 2023 8:22 pm
Thank you. Fingers crossed it gets sorted 🤞
PostPosted: Tue Feb 07, 2023 1:17 am
BETA044 is available, this issue should be solved.
Note: We've done some somewhat risky I/O GUI code rewrites; if you run into weird sound card issues, it's probably not you but us, so please let us know.
PostPosted: Tue Feb 07, 2023 2:30 am
Nice. However I'm having trouble with WatchCat now. Is anybody able to get it to work? It's not fully processing, leaving a blank file to render out, which ends up being 5-7kb in ogg. I tried disabling processing altogether, same issue.
PostPosted: Tue Feb 07, 2023 3:51 am
I don`t know if this is a problem and why is that way, but the Sound card names in the MME section are with shrinked names(not full), like in Kernel section or WASAPI section.
Check pictures.
I try to set different sections sound card and so far no issues appeared, no errors.
P.S: I`m not facing the NAN error in AutoEQ anymore. So, i consider it`s fixed.
PostPosted: Tue Feb 07, 2023 10:34 am
Check pictures.
That's normal, MME only support 32-character names, and many sound card drivers apparently don't take that into account, so they get cut off.
