Post new topic  Reply to topic  [ 257 posts ]  Go to page Previous 121 22 23 24 25 26 Next
PostPosted: Sat Oct 08, 2022 4:30 pm
I had to clear out all other recent ST DSP plugins to keep Winamp from crashing for 067 :roll: but seems to be running fine :mrgreen:
The DLL's, not the settings?
PostPosted: Sat Oct 08, 2022 4:31 pm
So where we put address?
Oh, that shouldn't have been in the list for input 2 :( .
PostPosted: Sat Oct 08, 2022 6:13 pm
Yes, the DLL's. Using the previous settings without issue.
PostPosted: Sat Oct 08, 2022 11:00 pm
Ever since beta 29 for 9.92, using VST2-32 with Adobe audition 3, when I open Stereotool. all I see is a blank white screen. I just tried it again today with beta 67. Is this a known problem?
Ted Alexander W8IXY
PostPosted: Sat Oct 08, 2022 11:36 pm
Ted Alexander W8IXY
Hi, no, this is not a known issue. I just tried it here (in a different version of Audition), and here it opens fine, but with a too small window. Aside from that everything seems to work fine.
Can you send me your VST .ini file in a PM? It's usually in C:\Users\username\vst_stereo_tool.ini
Edit: I found a bug that explains the wrong window size. I don't know if this also causes the white screen on your end, but it might. I'll run a new build tonight.
Do you know if it started in exactly BETA029? That one is pretty old (several months), and I don't see any size-issues in that version, they were introduced later (about 2 weeks ago).
PostPosted: Sun Oct 09, 2022 9:41 pm
BETA068 is posted; only change is the fix for the VST display size for the old GUI.
PostPosted: Tue Oct 11, 2022 1:50 am
Here is the vst.ini file you requested. Version 29 was the last one that the GUI worked with Adobe Autition 3. Using Windows 10.
[Direct soundcard access]
[FM Transmitter]
Enable UECP=0
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/1s:\T2h\:\T02m\:\T02 ... 02m\:\T02s
RDS PTYN text=
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2017 - www.stereotool.com
UECP DSN=0
UECP Encoder Address=0
UECP PSN=0
UECP Port=4001
UECP Site Address=0
UECP listen on specific encoder address=0
UECP use standard RDS settings when connection closed=0
[PNR Low Latency Monitoring]
Block size=0
[PNR Normal]
Block size=0
[Presets]
Recent file 1=H:\1 Stereotool Presets\MAIN133 10 6 2018.sts
Recent file 10=H:\1 Stereotool Presets\2 futzing 17 10 18 2017.sts
Recent file 11=H:\1 Stereotool Presets\2 futzing 18 10 18 2017.sts
Recent file 12=H:\1 Stereotool Presets\2 futzing 16 10 18 2017.sts
Recent file 13=H:\1 Stereotool Presets\CD process for car 10 7 2017.sts
Recent file 14=H:\1 Stereotool Presets\CD process for car interim 9 11 2017.sts
Recent file 15=H:\1 Stereotool Presets\2 futzing 15 10 18 2017.sts
Recent file 16=H:\1 Stereotool Presets\2 futzing 13 10 17 2017.sts
Recent file 17=H:\1 Stereotool Presets\2 futzing 14 10 17 2017.sts
Recent file 18=H:\1 Stereotool Presets\2 futzing 4 10 17 2017.sts
Recent file 19=H:\1 Stereotool Presets\2 futzing 10 10 17 2017.sts
Recent file 2=H:\1 Stereotool Presets\MAIN 10 18 2017.sts
Recent file 20=H:\1 Stereotool Presets\2 futzing 1 10 17 2017.sts
Recent file 3=H:\1 Stereotool Presets\2 futzing 23 10 18 2017.sts
Recent file 4=H:\1 Stereotool Presets\2 futzing 20 10 18 2017.sts
Recent file 5=H:\1 Stereotool Presets\2 futzing 21 10 18 2017.sts
Recent file 6=H:\1 Stereotool Presets\2 futzing 22 10 18 2017.sts
Recent file 7=H:\1 Stereotool Presets\CD process for car 4 10 2017.sts
Recent file 8=H:\1 Stereotool Presets\CD process for car 7 26 2016.sts
Recent file 9=H:\1 Stereotool Presets\2 futzing 19 10 18 2017.sts
[SST Export]
Author=Thimeo Stereo Tool 9.10
Contains Cleanup=1
Contains FM=1
Contains Processing=1
Name=Imported from Stereo Tool
[ST Preset Info]
Software class=Thimeo
Software name=Thimeo Stereo Tool
Software version=9.10
[Stereo Tool Configuration]
Enable web interface=0
Extra info in title bar=
Password=
Port=8080
Software version=9.03 BETA033
Whitelist=127.0.0.1/32
[Stereo Tool Dynamic Settings]
Poll STS File name=
[Thimeo MicroMPX]
Stream hash key=
Thimeo MicroMPX IP 0=
Thimeo MicroMPX IP 1=
Thimeo MicroMPX IP 10=
Thimeo MicroMPX IP 11=
Thimeo MicroMPX IP 12=
Thimeo MicroMPX IP 13=
Thimeo MicroMPX IP 14=
Thimeo MicroMPX IP 15=
Thimeo MicroMPX IP 16=
Thimeo MicroMPX IP 17=
Thimeo MicroMPX IP 18=
Thimeo MicroMPX IP 19=
Thimeo MicroMPX IP 2=
Thimeo MicroMPX IP 20=
Thimeo MicroMPX IP 21=
Thimeo MicroMPX IP 22=
Thimeo MicroMPX IP 23=
Thimeo MicroMPX IP 24=
Thimeo MicroMPX IP 25=
Thimeo MicroMPX IP 26=
Thimeo MicroMPX IP 27=
Thimeo MicroMPX IP 28=
Thimeo MicroMPX IP 29=
Thimeo MicroMPX IP 3=
Thimeo MicroMPX IP 30=
Thimeo MicroMPX IP 31=
Thimeo MicroMPX IP 32=
Thimeo MicroMPX IP 33=
Thimeo MicroMPX IP 34=
Thimeo MicroMPX IP 35=
Thimeo MicroMPX IP 36=
Thimeo MicroMPX IP 37=
Thimeo MicroMPX IP 38=
Thimeo MicroMPX IP 39=
Thimeo MicroMPX IP 4=
Thimeo MicroMPX IP 40=
Thimeo MicroMPX IP 41=
Thimeo MicroMPX IP 42=
Thimeo MicroMPX IP 43=
Thimeo MicroMPX IP 44=
Thimeo MicroMPX IP 45=
Thimeo MicroMPX IP 46=
Thimeo MicroMPX IP 47=
Thimeo MicroMPX IP 48=
Thimeo MicroMPX IP 49=
Thimeo MicroMPX IP 5=
Thimeo MicroMPX IP 50=
Thimeo MicroMPX IP 51=
Thimeo MicroMPX IP 52=
Thimeo MicroMPX IP 53=
Thimeo MicroMPX IP 54=
Thimeo MicroMPX IP 55=
Thimeo MicroMPX IP 56=
Thimeo MicroMPX IP 57=
Thimeo MicroMPX IP 58=
Thimeo MicroMPX IP 59=
Thimeo MicroMPX IP 6=
Thimeo MicroMPX IP 60=
Thimeo MicroMPX IP 61=
Thimeo MicroMPX IP 62=
Thimeo MicroMPX IP 63=
Thimeo MicroMPX IP 64=
Thimeo MicroMPX IP 65=
Thimeo MicroMPX IP 66=
Thimeo MicroMPX IP 67=
Thimeo MicroMPX IP 68=
Thimeo MicroMPX IP 69=
Thimeo MicroMPX IP 7=
Thimeo MicroMPX IP 70=
Thimeo MicroMPX IP 71=
Thimeo MicroMPX IP 72=
Thimeo MicroMPX IP 73=
Thimeo MicroMPX IP 74=
Thimeo MicroMPX IP 75=
Thimeo MicroMPX IP 76=
Thimeo MicroMPX IP 77=
Thimeo MicroMPX IP 78=
Thimeo MicroMPX IP 79=
Thimeo MicroMPX IP 8=
Thimeo MicroMPX IP 80=
Thimeo MicroMPX IP 81=
Thimeo MicroMPX IP 82=
Thimeo MicroMPX IP 83=
Thimeo MicroMPX IP 84=
Thimeo MicroMPX IP 85=
Thimeo MicroMPX IP 86=
Thimeo MicroMPX IP 87=
Thimeo MicroMPX IP 88=
Thimeo MicroMPX IP 89=
Thimeo MicroMPX IP 9=
Thimeo MicroMPX IP 90=
Thimeo MicroMPX IP 91=
Thimeo MicroMPX IP 92=
Thimeo MicroMPX IP 93=
Thimeo MicroMPX IP 94=
Thimeo MicroMPX IP 95=
Thimeo MicroMPX IP 96=
Thimeo MicroMPX IP 97=
Thimeo MicroMPX IP 98=
Thimeo MicroMPX IP 99=
PostPosted: Tue Oct 11, 2022 1:58 am
I just loaded BETA 68 VST 32 and it still opens only to a blank white screen. Adobe Audition 3, Windows 10.
Ted Alexander
PostPosted: Tue Oct 11, 2022 8:07 am
Oh! I misunderstood your earlier post - I thought version 29 was the first one that *didn't* work. So, does this mean that 030 was already broken? I just looked through all the code changes between 029 and 031 and I don't see anything suspicious.
The .ini file looks really old - the last version that wrote to it was version 9.10 from several years ago. So I think there's a newer .ini file (did you rename the VST DLL?)
Are you loading existing settings or are you creating a new VST plugin instance in Audition? If you're loading existing settings, something in those settings might trigger the crash.
I have sent you a PM.
PostPosted: Wed Oct 12, 2022 3:14 am
Hi Hans. I didn't see a PM. (It may have been caught in my spam folder and deleted.)
I hadn't been loading every Beta, just the several I mentioned before. The first problem I had was with BETA 35, which was the Beta I loaded after 29.
I have kept a VST DLL file in a folder in one of my drives for several years now. I just add each BETA I download to that file/folder. Should I start a new folder? Or should I delete the old .ini file completely and start over? How do I change the latese .ini file?
I appreciate your advice. I know I still use the old Adobe Audition 3 VST2. It does everything I need it to do, nothing more,nothing less.
Ted Alexander
w8ixyw8ixyw8ixy@gmail.com
