BETA601-012:
- Most of the performance loss for HIGHER sample rates is restored.
- Upsampling and downsampling quality has been improved again! So output is again cleaner.
Winamp DSP plugin:
http://www.stereotool.com/download/dsp_ ... 01-012.exe
Stand alone version:
http://www.stereotool.com/download/ster ... 01-012.exe
VST version:
http://www.stereotool.com/download/vst_ ... 01-012.dll
VST version (No SSE2):
Command line version:
Linux command line version:
http://www.stereotool.com/download/ster ... ETA601-012 [not available]
Linux GUI version:
What remains for 6.01:
- Performance: Multiband steepness: Moving UP can be done inside current loop, no separate loop needed
- Performance: Multiband: Remove sqrt(sqrt(cos())), pow(x, .75) etc. - too expensive, replace by lookup table.
- Reduce downsampling frequency because currently very high frequencies (21-22 kHz @ 176.4 kHz input sampling rate) in the input can cause spikes even if Hard Limit is used.
- And I need to check how much the performance is impacted by the latency improvements, in the case where no upsampling and downsampling is needed. This seems to be impacted way more than I expected (could also be Multiband steepness).
- MAYBE: Make Steepness smarter. That would much better preserve the audio, especially at very low latencies! How: Instead of setting all the levels at AT MOST the level of neighboring bands + a bit, combine adjacent bands, determine total output level, and then fix it such that this combined output level is approached more. (So one very low, one very high --> one a bit less low, one a bit less high instead of both low).
- Fix NOISE GATE behavior in VST plugin
Questions:
* Multiband: Question: Is Steepness behavior ok?
* Loudness: QUESTION: The changed Punch behavior, is that good or bad?
Check:
Check difference in behavior between 44.1 and 48 kHz input for multiband! This could potentially result in really big differences.
